Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Crash (Endless loop) on any iteract to non-First row of DataGridView
Maxim-CADman77
Advisor Advisor
Maxim-CADman77
(this thread seems related to general programming but as soon as I suffer the issue in context of Inventor-relatad project I hope it is not too-much off-topic  here)
In one of my Inventor-related projects I'd like to provide user with Windows Form containing controls of some options (CheckBoxes) organized with DataGridView.
Here is a very simplified (Paint-created) version of the desired form:
Pay attention there are some <empty> (not an option) cells.
The hard thing of this task - irregularity of the CheckBoxCell pattern (should be generated dynamically according to some business logic that is not an object of this thread).
Initially I thought I need to use Boolean type for Columns where CheckBoxes are to be placed but that seems to be the wrong way (AFAIK CheckBoxCell can't be converted to an <empty cell>, at least all my attempts to do so were unsuccessful, see commented).
Then I search Internet a bit and found a mention that opposite conversation (from TextBoxCell to CheckBoxCell is possible).
Using this knowledge I get some progress towards the desired.
Now I can convert <empty cell> to checkbox with following iLogic code (see the DataBindingComplete sub):
Option Explicit On
AddReference "System.Data"
AddReference "System.Xml"
Imports System.Data
Imports System.Windows.Forms
Class AAA
Friend WithEvents oDGV As New DataGridView
Dim sHeader1 As String = "Name"
Dim sHeader2 As String = "Option1"
Dim sHeader3 As String = "Option2"
Sub Main
Dim oDT As DataTable = New DataTable
oDT.Columns.Add(sHeader1, GetType(String))
oDT.Columns.Add(sHeader2, GetType(String)) ' GetType(Boolean))
oDT.Columns.Add(sHeader3, GetType(String)) ' GetType(Boolean))
Dim names = New List(Of String)
names.Add("A1")
names.Add("A2")
' Dim opt1vals = New List(Of String)
' opt1vals.Add(False)
' opt1vals.Add(True)
' Dim opt2vals = New List(Of String)
' opt2vals.Add(True)
' opt2vals.Add(False)
Dim i As Integer = 0
For Each name in Names
	oDT.Rows.Add(oDT.Columns.Count)
	oDT.Rows(i)(sHeader1) = name
	' oDT.Rows(i)(sHeader2) = opt1vals(i)
	' oDT.Rows(i)(sHeader3) = opt2vals(i)
	i +=1
Next
Dim oDV As DataView = oDT.DefaultView
With oDGV
	.AllowUserToAddRows = False
	.AutoSize = True
	.DataSource = oDV
End With
Dim oForm As New Form
With oForm
	.AutoSize = True
	.Controls.Add(oDGV)
End With
' logger.info("oDGV.Rows.Count #1 = " & oDGV.Rows.Count)
oForm.ShowDialog()
End Sub
Sub oDGV_DataBindingComplete(ByVal sender As Object, ByVal E As DataGridViewBindingCompleteEventArgs) Handles oDGV.DataBindingComplete
	logger.info("oDGV.Rows.Count #2 = " & oDGV.Rows.Count)
	oDGV.Rows(0).Cells(sHeader3).Value = True
	oDGV.Rows(0).Cells(sHeader3) = New DataGridViewCheckBoxCell()
	' oDGV.Rows(1).Cells(sHeader2).Value = True ' !!! ENDLESS-LOOP
	' oDGV.Rows(1).Cells(sHeader2) = New DataGridViewCheckBoxCell()
End Sub
' Sub oDGV_DataBindingComplete(ByVal sender As Object, ByVal E As DataGridViewBindingCompleteEventArgs) Handles oDGV.DataBindingComplete
	' logger.info("oDGV.Rows.Count-2 = " & oDGV.Rows.Count)
	' oDGV.Rows(0).Cells(sHeader2).Value = False
	' oDGV.Rows(0).Cells(sHeader2) = New DataGridViewTextBoxCell()
	' oDGV.Rows(0).Cells(sHeader2).Value = ""
' End Sub
End Class
BUT for some reason this behaves as expected ONLY for cells of the first row (row index = 0).
As soon as I try to do this for a cell in the second row (row index = 1) the code crashes (after some time of endless cycling ... which I detect by means of iLogic Log panel).
But the problem seems not the conversation itself ... the code goes to endless cycle even if I comment-out those two lines related to the second row but try to interact with any cell of second row!
What I'm missing?
Please vote for Inventor-Idea Text Search within Option Names
Maxim-CADman77
I've managed to get a bit closer to what I want with approach of disabling existing checkbox with the code based on CellPainting Event handle:
Option Explicit On
AddReference "System.Drawing"
Imports System.Data
Imports System.Drawing
Class AAA
Sub Main
oDT.Columns.Add(sHeader2, GetType(Boolean))
oDT.Columns.Add(sHeader3, GetType(Boolean))
names.Add("A1")
names.Add("A2")
opt1vals.Add(False)
opt1vals.Add(True)
opt2vals.Add(True)
opt2vals.Add(False)
	i +=1
Next
With oDGV
	.AutoSize = True
	.DataSource = oDV
End With
With oForm
	.AutoSize = True
	.Controls.Add(oDGV)
End With
oForm.ShowDialog()
End Sub
Sub oDGV_CellPainting(ByVal sender As Object, ByVal e As DataGridViewCellPaintingEventArgs) Handles oDGV.CellPainting
	logger.info(1)
	' If e.RowIndex = 0 And e.ColumnIndex = 1 ' sHeader2
		' Dim cell1 As DataGridViewCell = oDGV.Rows(0).Cells(sHeader2)
		' Dim chkCell1 As DataGridViewCheckBoxCell = TryCast(cell1, DataGridViewCheckBoxCell)
		' chkCell1.Value = False
		' chkCell1.FlatStyle = FlatStyle.Flat
		' chkCell1.Style.ForeColor = Color.DarkGray
		' cell1.ReadOnly = True
	' End If
	If e.RowIndex = 1 And e.ColumnIndex = 2
		Dim cell2 As DataGridViewCell = oDGV.Rows(1).Cells(sHeader3)
		Dim chkCell2 As DataGridViewCheckBoxCell = TryCast(cell2, DataGridViewCheckBoxCell)
		chkCell2.Value = False
		chkCell2.FlatStyle = FlatStyle.Flat
		chkCell2.Style.ForeColor = Color.DarkGray
		cell2.ReadOnly = True
	End If
End Sub
End Class
Now I can clear disable checkboxes not only in the first row.
But I still worry about the fact that the sub is called 24 times for single cell and get to endless cycle (at least without crashing) if un-comment the code lines related to the checkbox in a first row ...
... I believe it will crash on real check box chart with dozens checkboxes.
Any ideas?
Maxim-CADman77
Ok endless loop seems to be triggered with cell value line(s):
chkCell1.Value = True
Event Handler Sub shouldn't contain lines changing cells' values.
I still don't understand why the sub is triggered so many times yet now I got more-or-less what I need without endless cycle.
PS:
I'll keep the thread open for some time in case somebody want to share a better solution.
Maxim-CADman77
The form I'm working on will have much more options than names thus I decided to optimize it a bit - swap rows with columns (AFAIK such table transformation is called "Pivot") but got to some re-paint issue that I don't understand how to overcome.
My current code is:
Option Explicit On
Imports System.Data
Class UserSetsForm
Dim sHeader1 As String = "   "
Dim sHeaderIPT As String = "*.ipt"
Dim sHeaderIAM As String = "*.iam"
Dim sHeaderIDW As String = "*.idw"
Sub Main
Dim optNames = New List(Of String)
optNames.AddRange({"00-AAA", "2D-AAA", "3D-AAA", "00-ABC", "2D-ABC", "3D-ABC"})
Dim oDT As DataTable = dataTableVERT(optNames)
' Dim oDT As DataTable = dataTableHOR(optNames)
With oDGV
	.AutoSize = True
	.AutoSizeColumnsMode = DataGridViewAutoSizeColumnsMode.AllCells
	.BackgroundColor = Drawing.Color.White
	.DataSource = oDV
End With
With oForm
	.AutoSize = True
	.Controls.Add(oDGV)
End With
oForm.ShowDialog()
End Sub
Function dataTableVERT(optNames As List(Of String)) As dataTable
	Dim oDT_V As DataTable = New DataTable
	oDT_V.Columns.Add(sHeader1, GetType(String))
	oDT_V.Columns.Add(sHeaderIPT, GetType(Boolean))
	oDT_V.Columns.Add(sHeaderIAM, GetType(Boolean))
	oDT_V.Columns.Add(sHeaderIDW, GetType(Boolean))
	For Each cn in optNames
		oDT_V.Rows.Add(oDT_V.Columns.Count)
		oDT_V.Rows(i)(sHeader1) = cn
		i +=1
	Next
	Return oDT_V
End Function
Function dataTableHOR(optNames As List(Of String)) As dataTable
	Dim oDT_H As DataTable = New DataTable
	oDT_H.Columns.Add(sHeader1, GetType(String))
		oDT_H.Columns.Add(cn, GetType(Boolean))
	Next
	oDT_H.Rows.Add(oDT_H.Columns.Count)
	oDT_H.Rows(0)(sHeader1) = sHeaderIPT
	oDT_H.Rows(1)(sHeader1) = sHeaderIAM
	oDT_H.Rows(2)(sHeader1) = sHeaderIDW
	Return oDT_H
End Function
Sub ChkBoxDisable(cell As DataGridViewCell)
	Dim chkCell As DataGridViewCheckBoxCell = TryCast(cell, DataGridViewCheckBoxCell)
	chkCell.FlatStyle = FlatStyle.Flat
	chkCell.Style.ForeColor = Color.DarkGray
	cell.ReadOnly = True
End Sub
	''' Disable choosing non-applicable check-boxes
	If e.RowIndex >= 0 And e.ColumnIndex >= 1
		Dim row As DataGridViewRow = oDGV.Rows(e.RowIndex)
		Dim column As DataGridViewColumn = oDGV.Columns(e.ColumnIndex)
		Select Case True
			''' CASES-for-VERTICAL-table
			Case row.Cells(sHeader1).Value.StartsWith("2D-") And (column.HeaderText = sHeaderIPT OR column.HeaderText = sHeaderIAM)
				ChkBoxDisable(oDGV.Rows(e.RowIndex).Cells(sHeaderIAM))
				ChkBoxDisable(oDGV.Rows(e.RowIndex).Cells(sHeaderIPT))
			Case row.Cells(sHeader1).Value.StartsWith("3D-") And (column.HeaderText = sHeaderIDW)
				ChkBoxDisable(oDGV.Rows(e.RowIndex).Cells(sHeaderIDW))
			''' CASES-for-HORIOZONTAL-table (??? poor-painting ???)
			Case column.HeaderText.StartsWith("2D-") AndAlso (row.Cells(sHeader1).Value = sHeaderIPT OR row.Cells(sHeader1).Value = sHeaderIAM)
				ChkBoxDisable(oDGV.Rows(sHeaderIPT).Cells(e.ColumnIndex))
				ChkBoxDisable(oDGV.Rows(sHeaderIAM).Cells(e.ColumnIndex))
			Case column.HeaderText.StartsWith("3D-") AndAlso row.Cells(sHeader1).Value = sHeaderIDW
				ChkBoxDisable(oDGV.Rows(sHeaderIDW).Cells(e.ColumnIndex))
		End Select
	End If
End Sub
End Class
If DataTable is created as Vertical (line 26) then I get 100% OK result:
But if DataTable is created Horizontal/"Pivoted" (line 27) then most cells got stuck until hovered with mouse pointer (but even re-drawed with pointer the disabled checkboxes are not shown):
PS:
Dear @MjDeck I'm very sorry for disturbing you but, I understand that this thread is not Inventor-related but kindly hope you can look into and comment on this.
MjDeck
Hi Maxim - the CellPainting event is not a good place to do this. That's more suited for customizing the appearance of the cell.
Here's a new version of your rule. This sets the read-only state with the same logic that you were using in oDgv_CellPainting. But it does it in the Form.Shown event. The system will call that only once, and it will call it after the DataGridView has been populated. So that's a good time to set some cells to read-only.
I also made a small change to the Rows.Add() lines. You were calling them with the columns count as an argument. I think that value is ignored, so I took it out just to make the code more clear. Let me know if I missed something here.
Mike Deck
Software Developer
Autodesk, Inc.
