@ysbaodnj,
Not sure what you will use this for, but I liked the challenge. Here is a scalable option:
Sub Main
Dim aDoc As AssemblyDocument = TryCast(ThisApplication.ActiveDocument, AssemblyDocument)
If IsNothing(aDoc) Then Logger.Debug("Not Run In Assembly Document") : Exit Sub
iLogicVb.Automation.LogControl.Level = LogLevel.Trace
Dim FeatureTypesToCount As New List(Of ObjectTypeEnum)
FeatureTypesToCount.AddRange({ObjectTypeEnum.kExtrudeFeatureObject, ObjectTypeEnum.kSweepFeatureObject, ObjectTypeEnum.kCombineFeatureObject })
Dim WorkObjectsToCount As New List(Of String)
WorkObjectsToCount.AddRange({"WorkPoint", "WorkAxis", "WorkPlane", "WorkSurface", "UCS" })
Dim OtherObjectsToCount As New List(Of String)
OtherObjectsToCount.AddRange({"Sketch", "Sketch3D" }) 'Anything added needs manual programming in Function: "GetOtherObjectCount"
Call CountAssemblyFeatures(aDoc, WorkObjectsToCount, OtherObjectsToCount, FeatureTypesToCount)
For Each refDoc As Document In aDoc.ReferencedDocuments
If aDoc.ComponentDefinition.Occurrences.AllReferencedOccurrences(refDoc).Count < 1 Then Continue For
If refDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject
Call CountAssemblyFeatures(refDoc, WorkObjectsToCount, OtherObjectsToCount, FeatureTypesToCount)
Else If refDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject
Call CountPartFeatures(refDoc, WorkObjectsToCount, OtherObjectsToCount, FeatureTypesToCount)
End If
Next
Dim tempFileName As String = System.IO.Path.ChangeExtension(System.IO.Path.GetTempFileName(), ".txt")
iLogicVb.Automation.LogControl.SaveLogAs(tempFileName)
Dim AllLogText As String = System.IO.File.ReadAllText(tempFileName)
Dim MarkerString As String = ": >>---------------------------"
Dim MarkerIndex As Integer = AllLogText.LastIndexOf(MarkerString) + MarkerString.Length+2
System.IO.File.WriteAllText(tempFileName, AllLogText.Substring(MarkerIndex))
Shell("notepad.exe " & tempFileName, vbNormalFocus)
End Sub
Sub CountPartFeatures(pDoc As PartDocument, WorkObjectsToCount As List(Of String), OtherObjectsToCount As List(Of String), FeatureTypesToCount As List(Of ObjectTypeEnum))
Dim countingMap As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap
For Each s As String In WorkObjectsToCount
countingMap.Add(s, GetWorkObjectCount(s, pDoc))
Next
For Each s As String In OtherObjectsToCount
countingMap.Add(s, GetOtherObjectCount(s, pDoc))
Next
For Each ObjTypeEnum As ObjectTypeEnum In FeatureTypesToCount
Dim StrippedName As String = Mid(CType(ObjTypeEnum, ObjectTypeEnum).ToString, 2, CType(ObjTypeEnum, ObjectTypeEnum).ToString.Length-7)
countingMap.Add(StrippedName, pDoc.ComponentDefinition.Features.OfType(Of PartFeature).Where(Function(d) d.Type = ObjTypeEnum).Count)
Next
Call ExportResults(pDoc.DisplayName, countingMap)
End Sub
Sub CountAssemblyFeatures(aDoc As AssemblyDocument, WorkObjectsToCount As List(Of String), OtherObjectsToCount As List(Of String), FeatureTypesToCount As List(Of ObjectTypeEnum))
countingMap.Add(s, GetWorkObjectCount(s, aDoc))
Next
countingMap.Add(s, GetOtherObjectCount(s, aDoc))
Next
countingMap.Add(StrippedName, aDoc.ComponentDefinition.Features.OfType(Of PartFeature).Where(Function(d) d.Type = ObjTypeEnum).Count)
Next
Call ExportResults(aDoc.DisplayName, countingMap)
End Sub
Sub ExportResults(DocDisplayName As String, countedMap As NameValueMap)
Logger.Trace(DocDisplayName & " Feature Counts:")
For i = 1 To countedMap.Count
If countedMap.Value(countedMap.Name(i)) < 0 Then Continue For 'Exlcudes pre-built errors for hard call failures of non-existant objects
If countedMap.Value(countedMap.Name(i)) < 1 Then Continue For 'Excludes lines for 0 results
Logger.Trace(" " & countedMap.Name(i) & ": " & countedMap.Value(countedMap.Name(i)).ToString)
Next
End Sub
Function GetWorkObjectCount(ObjectName As String, Doc As Document) As Integer
Select Case ObjectName
Case "WorkPoint"
Return Doc.ComponentDefinition.WorkPoints.Count-1
Case "WorkAxis"
Return Doc.ComponentDefinition.WorkAxes.Count-3
Case "WorkPlane"
Return Doc.ComponentDefinition.WorkPlanes.Count-3
Case "WorkSurface"
Try
Return Doc.ComponentDefinition.WorkSurfaces.Count
Catch
Return -1 'WorkSurfaceObject Doesn't exist for assemblies
End Try
Case "UCS"
Return Doc.ComponentDefinition.UserCoordinateSystems.Count
End Select
Logger.Debug(ObjectName & " not setup in Function: ""GetWorkObjectCount""")
Return -1
End Function
Function GetOtherObjectCount(ObjectName As String, Doc As Document) As Integer
Case "Sketch"
Return Doc.ComponentDefinition.Sketches.Count
Case "Sketch3D"
Try
Return Doc.ComponentDefinition.Sketches3D.Count
Catch
Return -1 'Sketch3DObject Doesn't exist for assemblies
End Try
End Select
Logger.Debug(ObjectName & " not setup in Function: ""GetOtherObjectCount""")
Return -1
End Function
Anything that is not a PartFeature, will need to be added to the "OtherObjectsToCount" list and manually programmed in the "GetOtherObjectCount" Function. I included 2D and 3D sketches in that function for examples. Part Features can be added by including the ObjectTypeEnum in the "FeatureTypesToCount" list.
The rule will display results in Logger and create a temp text file in the temp folder.
