counting assembly occurrences
NachitoMax
NachitoMax
Hi
What is the fastest, easiest, most simple way of counting individual occurrences? Lets say i have 50 components in my assembly-
10 x Wood Screw
10 x MDF Panel
10 x Plywood Back
10 x Top Panel
10 x Base Panel
instead of looping through to get 100 messageboxes each showing the same object 10 times
(wood Screw:1, Wood Screw:2 etc),
i need to get 5 message boxes showing the description & quantity
(Wood Screw x 10)
is there a way of counting occurrences in an assembly and just looping through them for a count?
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
GosponZ
I'm just thinking loud.
Isn't that Bom what you just said ? Do you really need msg box to tell you what you have in bom? Give more info to better understand what intension you have.
NachitoMax
Hi
I was using the msgbox purely for example to demonstrate 5 returns for a component definition instead of 20
I'll give a different description when I get home if it helps.
Cheers
Nacho
I faced the same problem some weeks ago, I found answers in these links:
http://modthemachine.typepad.com/my_weblog/2009/03/accessing-assembly-components.html
http://forums.autodesk.com/t5/inventor-customization/bom-structured-view-in-an-txt/m-p/5501530#M5402...
Usually Instead of having a messagebox I use .txt writer saving in spacific folder.
Bye
