Copy View from a file
bwang-tecoustics
bwang-tecoustics
I was able to use view.copyto to copy views from a file to another file when I have the source drawing open in inventor. But when I try to copy views from an ApprenticeServerDocument, I can read view names and locations but can not copy the views. Is this because ApprenticeServerDocument can only provide access to the drawing's properties but can't use the methods of the objects? Any one can help me on this?
        Dim dwgDoc As DrawingDocument
        dwgDoc = _invApp.ActiveDocument
        Dim dwgSheet As Sheet
        dwgSheet = dwgDoc.ActiveSheet
        Dim oApprentice As ApprenticeServerComponent
        oApprentice = New ApprenticeServerComponent
        Dim oADoc As ApprenticeServerDocument
        oADoc = oApprentice.Open("D:\Drawing1.idw")
        MsgBox(oADoc.DocumentType.ToString)
        Dim oASheets As Sheets
        oASheets = oADoc.Sheets
        For Each sht As Sheet In oASheets
            MsgBox(sht.Name)
            Dim oADViews As DrawingViews
            oADViews = sht.DrawingViews
            For Each oVw As DrawingView In oADViews
                MsgBox(oVw.Name & " is " & oVw.ViewType.ToString & ", at " & oVw.Position.X.ToString & ", " & oVw.Position.Y.ToString)
                Try
                    oVw.CopyTo(dwgSheet)
                Catch ex As Exception
                    MsgBox("Copy Faled.")
                End Try
            Next
        Next
        oADoc.Close()
        oApprentice.Close()
NachitoMax
Hi
As far as I know, Apprentice doesn't contain any UI capabilities so objects like Drawing Views may not be accessible. You could try opening the drawing instead as invisible
Dim InvApplication As Inventor.Application =
    ' System.Runtime.InteropServices.Marshal.
    '  GetActiveObject("Inventor.Application")
Dim sPath As String = "C:/My Folder/ MyDrawing.idw"
Dim oIDW As Inventor.DrawingDocument = InvApplication.Documents.Open(sPath, False)
don't forget to close it after
oIDW.Close
oIDW = nothing
Nacho
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
