- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello together,
I have a part with a UCS inside. This part is placed in an assembly. I would like create a new UCS in the assembly with the same orientation as the part UCS.
Dim oDoc As Document
oDoc = m_invApp.ActiveDocument
Dim CompDefs As AssemblyComponentDefinitions
CompDefs = oDoc.ComponentDefinitions
Dim oCompDef As AssemblyComponentDefinition
oCompDef = CompDefs.Item(1)
Dim oWx As Inventor.WorkAxis
oWx = m_invApp.CommandManager.Pick(SelectionFilterEnum.kWorkAxisFilter, "Please select WorkAxis:")
If oWx.IsCoordinateSystemElement Then
Dim oWxNodeDef As Inventor.NativeBrowserNodeDefinition
Dim oWxNode As Inventor.BrowserNode
oWxNodeDef = oDoc.BrowserPanes.GetNativeBrowserNodeDefinition(oWx)
oWxNode = oDoc.BrowserPanes.ActivePane.TopNode.AllReferencedNodes(oWxNodeDef).Item(1)
Dim oUCS As Inventor.UserCoordinateSystem
oUCS = oWxNode.Parent.NativeObject
Dim oTransMatrix As Matrix
oTransMatrix = oUCS.Transformation
End If
How could I do this?
Georg
