Copy Title block , sheetformat , border from one drawing to another drawing
sripandian
sripandian
Hi friends , i already know how to copy title block definition ,border but while copying sheet format i am facing issue.
In Title block folder in Browser ,'Copy of ISO' comes while using copyto function for copying each sheet format.im sheet format i have more than 6 sheet formats. Kindly anyone give example to copy Title block , sheetformat , border from one drawing.
bshbsh
Here's something similar to what I use: (VBA code)
Public Sub CopyDrawingResources()
    If ThisApplication.ActiveDocument Is Nothing Then
        Exit Sub
    Else
        If ThisApplication.ActiveDocument.DocumentType = kDrawingDocumentObject Then
            Dim InvDoc As Document
            Set InvDoc = ThisApplication.ActiveDocument
        Else
            Exit Sub
        End If
    End If
    Dim SourceDoc As DrawingDocument
    Set SourceDoc = ThisApplication.Documents.Open("PATH\TO\THE\SOURCE.idw", False)
    On Error Resume Next
    For Each Item In InvDoc.SheetFormats
        Item.Delete
    Next
    For Each Item In InvDoc.BorderDefinitions
        If Item.IsReferenced = False Then Item.Delete
    Next
    For Each Item In InvDoc.TitleBlockDefinitions
    Next
    For Each Item In InvDoc.SketchedSymbolDefinitions
    Next
    For Each Item In SourceDoc.BorderDefinitions
        Set TargetBorder = Item.CopyTo(InvDoc, True)
    Next
    For Each Item In SourceDoc.TitleBlockDefinitions
        Set TargetHeader = Item.CopyTo(InvDoc, True)
    Next
    For Each Item In SourceDoc.SketchedSymbolDefinitions
        Set TargetSymbol = Item.CopyTo(InvDoc, True)
    Next
    For Each Item In SourceDoc.SheetFormats
        'Caution: this creates a new copy of the TitleBlock used for EACH SheetFormat,
        'regardless if the TitleBlockDefinition already exists or not!!!
        Set TargetSheet = Item.CopyTo(InvDoc)
    Next
    On Error GoTo 0
    SourceDoc.ReleaseReference
    SourceDoc.Close (True)
    Set SourceDoc = Nothing
End Sub
I do not copy the SheetFormats, because it makes a mess with a lot of copies of the titleblock. Does anyone know what's up with that and how to fix it? I can not replace the titleblockdefinitions in sheetformats, they're read-only.
eric.frissell26WKQ
hey @bshbsh, you replied to my macro help the other day with this link.  Had a question for you about this code
Next
This means that if the item is referenced by your original document (the one you intend to change) that it doesn't delete the information?  If I set this to True would it delete the information/border/titleblock that the original document is using?
My way forward is going to be deleting the instance and copying in new ones and activating them.
Secondly when I run this script it's somehow copying one titleblock 6 times and calls it copy of (titleblock name) then copy of copy of (titleblock name).
Thanks for the help
bshbsh
Next
 yes. but this code is there to prevent error messages, because you can not delete referenced blocks.
no, most likely it will just cause errors. besides, even if it would delete them, it would not delete the non-referenced stuff.
then delete or comment out the last for-next loop, as the remarks specifically warns you what is going to happen if you do that... did you not read them?
eric.frissell26WKQ
I was able to find some of the errors but I see what you're saying by not deleting the referenced code
