Copy an iProp to item number column
g.grajdeanu
g.grajdeanu
I am trying to do modify  a vba code  in order to copy an existing custom prop. in Item number column from BOM in  each assembly.
In my mind will be like this:
1-Open ref doc (only those who have SBG or ET at stock number),
2 - copy Position to item number
3-save and close
(Silent runs for everyone)
I have part of code listed below if someone able to help me.
Sub Main()
    doc = ThisDoc.Document
    Dim oAssyDef As AssemblyComponentDefinition = doc.ComponentDefinition
    Dim oBOM As BOM = oAssyDef.BOM
    oBOM.StructuredViewEnabled = True
	oBOM.StructuredViewFirstLevelOnly = True
    Dim oBOMView As BOMView = oBOM.BOMViews.Item("Structured")
    Dim oBOMRow As BOMRow
    Dim oCompDef As ComponentDefinition
    For Each oBOMRow In oBOMView.BOMRows
      oCompDef = oBOMRow.ComponentDefinitions.Item(1)
      Call SetRowProps(oCompDef, oBOMRow.ItemNumber)
      If Not oBOMRow.ChildRows Is Nothing
          Call RecurseBOMRow(oBOMRow)
    Next
	oBOM.StructuredViewFirstLevelOnly = False
'	MessageBox.Show("Completed!", "iLogic",)
End Sub
Sub RecurseBOMRow(oBOMRow As BOMRow)
   For Each oBOMRow In oBOMRow.ChildRows
     Call SetRowProps(oCompDef, oBOMRow.ItemQuantity)
   Next
End Sub
Sub SetRowProps(oCompDef As ComponentDefinition, Stückzahl As String)
 Dim CompFullDocumentName As String = oCompDef.Document.FullDocumentName
 Dim CompFileNameOnly As String
 Dim index As Integer = CompFullDocumentName.LastIndexOf("\")
 CompFileNameOnly = CompFullDocumentName.Substring(index + 1)
 Dim indexFileExt As Integer = CompFileNameOnly.LastIndexOf(".")
 CompFileNameExtension = CompFileNameOnly.Substring (indexFileExt +1)
'MessageBox.Show(CompFileNameExtension, "CompFileNameExtensionn")
If CompFileNameExtension = "iam" Then
' MessageBox.Show(CompFileNameOnly,Position)
Dim File_Attr As Long
File_Attr = System.IO.File.GetAttributes(CompFullDocumentName)
If File_Attr = 1 Or File_Attr = 33 Then
'	MsgBox("the file is Read only")
 Else
	Position = iProperties.Value(CompFileNameOnly, "Inventor User Defined Properties", "Position")
Dim StockNumber As String
Dim PartName As String
StockNumber = iProperties.Value(oBaseName,"Project", "Stock Number")
PartName = iProperties.Value(oBaseName, "Project", "Part Number")
If (oBaseExtension = ".ipt") Then
		oNoOfIptFiles += 1
		If StockNumber <> "PT" And StockNumber <> "BL" Then
				End
		Else
	Else
		If (oBaseExtension = ".iam") Then
			oNoOfIamFiles += 1
			If StockNumber <> "BG" And StockNumber <> "SBG" And StockNumber <> "ET" Then
				GoTo NoW4Comp
			Else
Else
End Sub
g.grajdeanu
LE:
I tryed to split the code:
'Copy item number from BOM parts view to an iproperty in each component
'iproperty is named 'Position'
'assumptions:
'active doc is assembly
'LOD is master
Dim oAssDoc As AssemblyDocument
Dim oAssDef As AssemblyComponentDefinition
Dim oBOM As BOM
Dim oCustomProps As PropertySet
Dim oBOMNoProperty As Inventor.Property
Dim sItemNo As String
Const sPropName As String = "Position"
oAssDoc = ThisDoc.Document
oAssDef = oAssDoc.ComponentDefinition
oBOM = oAssDef.BOM
oCompDef = oBOMRow.ComponentDefinitions(1)
sItemNo = oBOMRow.ItemNumber
oCustomProps = oCompDef.Document.PropertySets("User Defined Properties")
Try
oBOMRow.ItemNumber = oCustomProps.Item(sPropName)
'oBOMRow.ItemNumber = sItemNo
Catch
oBOMRow.ItemNumber = iProperties.Value(CompFileNameOnly, "Inventor User Defined Properties", "Position") = Position
End Try
Next
g.grajdeanu
I did some research and i did find this post.
https://forums.autodesk.com/t5/inventor-customization/how-to-override-bom-itemnumber-without-parent-...
Based on it , is not posible, in 2021 to copy a custom prop into Item number column ?
Can anyone help me with this?
Dim Pos As String
Pos = oBOMRowPO.ItemNumber
iProperties.Value(CompFileNameOnly, "Custom", "#Pos") = Pos
