AddVbFile "Form - RichTextBox.Vb"
Sub Main
ShowCustomForm(600, 400, "Sample text")
End Sub
Solved by WCrihfield. Go to Solution.
Solved by Michael.Navara. Go to Solution.
Hi @JBerns. So, do you want to be able to use your Form code the way you showed in that small code window, or is that code window an example of how you do not want to have to use it?
Are you familiar with using the Property statement? Within your Class, you can have private, hidden variables to hold onto the values you pass in, for internal use, that are declared at the main Class level, outside of any Subs/Functions. Then you can also have Public Property statement blocks of code, where you can define Properties that your Class has for users to interact with. These can be declared as ReadOnly, or not. If not, then within that Property statement should be both a 'Set' statement, and a 'Get' statement, which dictate how the property works. The Set statement simply passed an 'input parameter' to your private/internal variable. The Get statement includes a 'Return' statement, just like a Function, and returns the value of your private/internal variable.
That is just one general idea. You could likely also combine the two Classes into one Class. But either way, you will likely need to use the 'New' keyword within the iLogic rule that uses your referenced Class, because you will need to create an instance of it, before you can use it. And if using the 'New' keyword, you could just directly pass those input variables into the 'New' Sub routine, instead of having to go though the secondary Class, or its ShowCustomForm routine. When the 'New' Sub routine has input variables, that is one of the two main ways to 'pass' data from the 'calling' routine (your regular rule) to the referenced Class. The other way is how I mentioned in the first paragraph...the Class having public properties. When that is the case, after you create a new instance of that Class, you then set those property values, before using any of the Subs/Functions within that Class. Not the cleanest way, if some of those Subs/Functions rely on those input variables though.
Edit: Forgot to mention the most important detail. When converting an external iLogic rule to a file that you can reference using 'AddVbFile', you must turn the 'Straight VB Code' option on. Doing so will usually show a brief warning, because that does change how the code is interpreted. For example, it becomes much more strict, and certain terms (like "ThisApplication") are no longer recognized, requiring alternative variables be created locally, and values being set to them. The Inventor.Application object is one of the most basic ones often passed from rules to externally referenced tools. Other common ones are the 'Rule Object' type objects.
And on a side note, if your external rule (turned into reference) contained a Module, instead of a Class, then you would not need to create an instance of it before using its methods. But those are a bit different to work with than Classes. Modules are also good for defining 'extension' helpers for existing object types.
Wesley Crihfield
(Not an Autodesk Employee)
I am personally not a fan of AddVBFile. I find that Inventor does not really recompile it properly when changes are made thus requiring a restart every time I edit the file.
I like to use ilogic rule runner instead and work off the input/output NameValueMap. This way I don't have to worry about straight vb code and can still use the default objects like ThisApplication in the child rule. And I don't have to restart inventor because it cached the old code from the AddVbFile statement.
Here is an example i use where I want to search vault for properties given a file name.
Dim map As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap()
map.Add("fPath", doc.FullFileName)
map.Add("fProps", {"State"})
iLogicVb.RunExternalRule("Vault - Get Property For Document.iLogicVb", map)
Dim returnvals = map.Item("fPropsRet")
Also if you set it up proper, you can use windows forms designer directly on ilogic rules without requiring an external dll. You are actually close to the required formatting with the example you posted.
Hi @g.georgiades. I like passing arguments between rules also, which keeps all code in iLogic realm. However, I did not realize that code from sources referenced with AddVbFile were held in Inventor's memory until closing Inventor. I am aware that if I create an event handler with an iLogic rule without a backdoor way to access it again, I will not be able to either change it or remove it, without restarting Inventor. So, you are saying that even after the rule that used the AddVbRule in its header has finished and closed...the code of the external source is still held in Inventor's memory until you close Inventor? If so then that does not sound very good. However, I only put code out into a file formatted that way after it has been thoroughly tested in my regular rules, and should not require any further changes, so it does not sound like a huge problem.
Wesley Crihfield
The external rule as it is now works, it just has static values.
I want to be able to pass arguments for width, height, text.
My goal is to make a better MsgBox that has scrollbars.
Jerry
My original goal was to make a better MsgBox. I could have used a TextBox control, but saw others asking about font, color, bold, etc. I chose to use a RichTextBox control to gain that text formatting.
It would be great if I could call the subroutine as shown (with arguments). Myself or others could enhance the code as needed to pass additional arguments to modify the WinForm.
If a few more lines of code are required, so be it. It would still likely be shorter than copy/paste 150+ lines of code for each rule that could use a better MsgBox.
To share this WinForm between rules, I figured the subroutine would have to be external and therefore loaded (declared), so I thought I could use AddVbFile. However, I could not seem to resolve the errors when using the AddVbFile statement:
I also tried adding the 'Straight Vb' option, but errors persisted.
The code works when I run from the External Rule tab of the iLogic browser, but many errors occur when I try to add the file to other rules.
I am aware of the public class properties and was experimenting with that before posting. Some success until I tried to use AddVbFile. If a few more declarations or lines of code are required, I could live with that.
* * * Is this a practical approach? Or should I have used a DLL? I would still want to pass arguments such as width, height, and text.
The goal to build a better mousetrap MsgBox seems to be getting complicated.
Jerry
This is relatively easy. See the attached sample code files.
The main rule looks like
AddReference "System.Drawing"
AddVbFile "IC_13026300_Dlg.vb"
Sub Main
CustomForm.ShowCustomForm(600, 400, "Sample text")
End Sub
In CustomForm implementaiton is important to create Shared (static C#) method, which creates new instance of CustomForm class and run its ShowDialog method and returns this result to the caller.
Public Shared Function ShowCustomForm(width As Integer, height As Integer, message As String) As DialogResult
Dim customForm As New CustomForm
customForm.Width = width
customForm.Height = height
customForm.RichTextBox1.Text = message
Return customForm.ShowDialog()
End Function
Full code is in attachment
Brilliant!! Thank you, Michael!
I hope others will find the benefit of this enhanced 'MsgBox'.
I look forward to using this solution.
Thank you also to @WCrihfield , @g.georgiades , and all who contributed.
Jerry
Hi @JBerns. I have another example you can look at and review. I will attach two text files, one will contain the code for the referenced Class called "RichMsg", while the other will contain the code for another example external iLogic rule that is using that referenced Class. This just uses the New method of the referenced Class to optionally specify the message, title, width, & height of the dialog. You can also simply not specify any of the optional inputs in the New routine, and specify them (or change them) later, after the instance has been created, because they are public properties of that Class, and setting their values applies those changes to the dialog.
One of the challenging things about creating referenced Classes that you intend to reference from other iLogic rules using AddVbFile is that we do not seem to be able to use the 'AddReference' lines within the header of those external rules. They will accept the 'Imports' statements, but not the references. So, I usually include the 'AddReference' lines (and the Imports lines) to the rule I we will be calling the referenced Class to run from. In the case of my attached example, it was initially complaining about there not being a reference to the 'System.Drawing' resource, where the 'Font' and 'Size' object Types are defined. I could have simply not included those in my example Class, but I am using them in only two key places. I am using a 'Size' to limit the minimum size of the Form. And I am using a 'Font' to customize how the text looks within the RichTextBox. I simply like 'Arial' Font, and I generally prefer slightly larger than normal font in some situations. But you can change that if wanted.
Wesley Crihfield
Another brilliant solution! Thank you, Wes!
This community is awesome.
