I need to transform a few hundreds of iParts (childs) into standard parts.
Is there any way of making this process automatic or semi automatic?
(i'm not keen in open each file to delete the table...)
Thank you
Solved by WCrihfield. Go to Solution.
Solved by bradeneuropeArthur. Go to Solution.
With this you can in ilogic:
Dim partDoc As PartDocument = ThisApplication.ActiveDocument If partDoc.ComponentDefinition.IsiPartMember Then partDoc.ComponentDefinition.iPartMember.BreakLinkToFactory Return 'do nothing Else MessageBox.Show("This is NOT an iPart", "Title") End If
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
Or with a selection via a dialog:
Dim d As Inventor.FileDialog Call ThisApplication.CreateFileDialog(d) d.MultiSelectEnabled = True d.Filter = "Parts|*.ipt" d.ShowOpen d.CancelError = False If Not d.FileName = "" Then Dim a() As String = Split(d.FileName, "|") i=0 For i = 0 To UBound(a) Dim partDoc As PartDocument = ThisApplication.Documents.Open(a(i)) If partDoc.ComponentDefinition.IsiPartMember Then partDoc.ComponentDefinition.iPartMember.BreakLinkToFactory Return 'do nothing Else MessageBox.Show("This is NOT an iPart", "Title") End If partDoc.Save partDoc.Close Next End If
Arthur Knoors
Hi @paulo.correia98ZAP. This is basically performing the same actions as @bradeneuropeArthur 's code, but lets you choose a directory/folder to process, instead of selecting multiple specific files. It will then process all Part documents in that folder. There is also a simple setting near the end of the oFiles() definition line, where you can change this from just processing the top/main directory, to then process all sub-folders if you wanted, but it is currently set to only process the top selected directory. It uses a regular 'Open File' dialog, that is set up to only select a folder (glorified folder selection dialog.)
Sub Main
Dim oTargetFolder As String = ChooseFolder
Dim oFileNames As New List(Of String)
Dim oFilter As String = "*.ipt"
Dim oFiles() As String = System.IO.Directory.GetFiles(oTargetFolder, oFilter, IO.SearchOption.TopDirectoryOnly)
oFileNames.AddRange(oFiles)
If oFileNames.Count = 0 Then
MsgBox("No files match the search criteria in the selected folder. Exiting.", , "")
Exit Sub
For Each oFile As String In oFiles
Dim oPDoc As PartDocument = ThisApplication.Documents.Open(oFile, False)
If oPDoc.ComponentDefinition.IsiPartMember Then
oPDoc.ComponentDefinition.iPartMember.BreakLinkToFactory
oPDoc.Save2(False)
oPDoc.Close(True)
Else
'MsgBox(oFile & vbCrLf & "Is not an iPart.",,"")
oPDoc.Close(True)
Next
End Sub
Private Function ChooseFolder() As String
Dim ThisApplication As Inventor.Application = GetObject(,"Inventor.Application")
Dim oFolder As String = ""
Dim oPlaceHolder As String = "PlaceHolderText"
Dim oDirSepChar As Char = System.IO.Path.DirectorySeparatorChar
Dim oOpenDlg As New System.Windows.Forms.OpenFileDialog
oOpenDlg.Title = "Select A Folder."
oOpenDlg.InitialDirectory = ThisApplication.DesignProjectManager.ActiveDesignProject.WorkspacePath
oOpenDlg.Filter = ""
oOpenDlg.Multiselect = False
oOpenDlg.RestoreDirectory = False
oOpenDlg.CheckFileExists = False
oOpenDlg.CheckPathExists = True
oOpenDlg.ValidateNames = False
oOpenDlg.FileName = oPlaceHolder
oOpenDlg.AddExtension = False
oOpenDlg.DefaultExt = ""
Dim oResult = oOpenDlg.ShowDialog
If oResult = vbOK Then
If oOpenDlg.FileName <> vbNullString Then
oFolder = oOpenDlg.FileName
Else
MsgBox("No file was selected. Exiting.", vbOKOnly + vbExclamation, "FILE NOT SELECTED")
Exit Function
ElseIf oResult = vbCancel Then
MsgBox("The dialog was Canceled. Exiting.", vbOKOnly + vbInformation, "CANCELED")
Exit Function
'count the number of characters from the end, until it finds the directory separator character
Dim oPos As Integer = InStr(StrReverse(oFolder), oDirSepChar)
'check if the directory separator character was at the end, if so, perfect, if not, eliminate end text
If oPos <> 1 Then
'the directory seperator character was not at the end, so...
oFolder = Strings.Left(oFolder, InStrRev(oFolder, oDirSepChar))
Return oFolder
End Function
Wesley Crihfield
(Not an Autodesk Employee)
@bradeneuropeArthur and @WCrihfield
Thank you so much.
This save me hours and the life is too short to spend in unproductive tasks 🙂
You guys are stars.
Paulo
