convert .igs files to 3D solid model
Message 1 of 10
Hello
We are attempting to take an .igs file (3D point cloud) to generate a 3D solid model. Does AUTOCAD have a feature to connect all of the points in a mesh to make a surface. Ideally, we would like  to use the point data to create solid.
Thank you,
Gerald
Replies (9)
Message 2 of 10
danijel.radenkovic
Hi Gerald,
Would you like to upload file, cause we have some tools to try to transform it to surface/solid geometry and give back to you?
Danijel
Inventor 2018/Windows 10 x64
If this information was helpful, please consider marking it as an Accepted Solution by using the Accept as Solution. Kudos are also gladly accepted.
Message 3 of 10
Hello Danijel
File is attached as a zip file.
Gerald
Message 4 of 10
danijel.radenkovic
Hi Gerald,
It seems that this .iges is empty. Can you export as .stl file?
Danijel
Message 5 of 10
File won't save as STL.  Saved it as IPT file and retest the file to make sure it's there.
Message 6 of 10
danijel.radenkovic
Hi Gerald,
I see now. This is not a typical mesh feature that can be converted to a solid feature. This is just a 3D sketch of points and can't be converted to a solid model. Probably can be redesigned if you have some drawings. Which software have you used to create this?
Danijel
Message 7 of 10
Hi Danijel
These points were generated from a CMM machine and exported as an iges file. We are trying to measure an existing real part an ultimately generate a 3D solid model form these points to accurately capture the shape and dimension of the real part.
Gerald
Message 8 of 10
danijel.radenkovic
Hi Gerald,
Do you have a possibility to export file as .pts or any other point cloud file extension?
Danijel
Message 9 of 10
Our team was able to export it to a pt file.
Message 10 of 10
danijel.radenkovic
Hi Gerald,
I am not sure that you have exported right points. File that I want to convert to surface/solid has many points. Your file has about hundred lines of text.
Regards
Danijel
