Announcements
convert a unit parameter
dessinumwb
dessinumwb
i'm using Iventor 2023,
Need an Ilogic to convert a user parameter, in to mm and vis versa.
It's almost working but something wrong some where!
the LG parameter is the input lenght and LGM is the result.
My need is when i enter a lenght  5270 mm (LG) , i need to see result like 207.48 in (LGM)
or in i enter a lenght 207.48 in (LG), i need to see result like 5270 mm (LGM)
here's the code i trying to make it work
Dim oParams As Parameters
oParams = ThisDoc.Document.ComponentDefinition​.Parameters
 Dim oParamName As Parameter
oParamName = oParams.Item("LGM")
If LG = kInchLengthUnits Then
      oParamName.Units = "mm"
  ElseIf LG = kMillimeterLengthUnits Then
      oParamName.Units = "in"
 ThisDoc.Document.Update
Thank you
dalton98
edit
you would need to setup an event trigger for 'Any User Parameter Change'
Dim oLG As Inventor.Parameter = oParams.Item("LG")
Dim oLGM As Inventor.Parameter = oParams.Item("LGM")
'fix LG units to input units
'oLG.Units = Right(oLG.Expression, 2)
oLG.Units = Right(oLG.Expression, oLG.Expression.Length - InStrRev(oLG.Expression, " "))
oLGM.Value = oLG.Value
Select Case oLG.Units
	Case "in", "ft", "mil", "nauticalmile"
		oLG.Units = "in"
		oLGM.Units = "mm"
	Case "mm", "cm", "m", "micron"
		oLG.Units = "mm"
		oLGM.Units = "in"
End Select
dessinumwb
Thank you, it's working perfectly
