Controlling Offset Orientation
benjamin.herinckx
benjamin.herinckx
Hi all,
v: Inventor Professional 2019
I'm trying to automate the hole command in the given fashion :
1 - select face
2 - project face
3 - offset projected lines
4 - Apply hole command to the hole centers
The code I have come up with works (more or less).
However on Step 3, the orientation of the projected line seem to alternate between inwards and outwards (should always be inwards)..
You will find a commented out section in my code trying to deal with the matter but it is not working as expected (that is, it does nothing..)
Can someone help me define the proper way to always offset a geometry inwards ?
Dim oDoc As Document = ThisApplication.ActiveDocument
Dim oCD As ComponentDefinition = oDoc.ComponentDefinition
Dim TG As TransientGeometry = ThisApplication.TransientGeometry
Dim oFace As Face
Dim oOffsetDir As Boolean = False
Do
oFace = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFacePlanarFilter, "Select Face to Place Sketch")
    If Not oFace Is Nothing Then
        Dim oSketch As Sketch = oCD.Sketches.Add(oFace, True)
        Dim oLineCollection As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
        Dim oPointCollection As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
        For Each oLine As SketchLine In oSketch.SketchLines
            oLine.Construction = True
            oLineCollection.Add(oLine)
        Next
        'Define the offset direction
        ' Dim Params(0 To 1) As Double
        ' Dim Normals(0 To 2) As Double
        ' Params(0) = 0
        ' Params(1) = 0
        ' oFace.Evaluator.GetNormal(Params, Normals)
        ' Dim oNormalVector As UnitVector = TG.CreateUnitVector(Normals(0), Normals(1), Normals(2))
        ' Dim oLineVector As UnitVector = TG.CreateUnitVector(oLineCollection.Item(1).Geometry.Direction.X,oLineCollection.Item(1).Geometry.Direction.Y,0)
        ' Dim oOffsetVector = oLineVector.CrossProduct(oNormalVector)
        ' If oOffsetVector.IsEqualTo(oDesiredVector) = True Then
        '     oOffsetDir = True
        ' Else
        '     oOffsetDir = False
        ' End If
        oSketch.OffsetSketchEntitiesUsingDistance(oLineCollection,40,oOffsetDir,False,True)
            If oLine.Construction = False Then
                oPointCollection.Add(oLine.EndSketchPoint)
                oPointCollection.Add(oLine.StartSketchPoint)
            End If
        Next
        For Each oPoint As SketchPoint In oPointCollection
            oPoint.HoleCenter = True
        Next
        oCD.Features.HoleFeatures.AddDrilledByThroughAllExtent(oPointCollection1, kPositiveExtentDirection)
    End If
Loop While Not oFace Is Nothing
HideoYamada
Hi Benjamin,
This is quick/dirty hack. Create both side lines and determine which line set is inside by the total length of them.
If the code will be used by just you, this may be enough.
option explicit on
Dim oFace As Face
Do
        Next
        Dim createdSetOne As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
        Dim createdSetTwo As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
        Dim createdTotalLengthOne As Double
        Dim createdTotalLengthTwo As Double
        For Each oLine As SketchLine In oSketch.OffsetSketchEntitiesUsingDistance(oLineCollection,40,True,False,True)
            createdTotalLengthOne = createdTotalLengthOne + oLine.Length
            createdSetOne.Add(oLine)
        Next oLine
        For Each oLine As SketchLine In oSketch.OffsetSketchEntitiesUsingDistance(oLineCollection,40,False,False,True)
            createdTotalLengthTwo = createdTotalLengthTwo + oLine.Length
            createdSetTwo.Add(oLine)
        Next oLine
        Dim insideSet As ObjectCollection
        Dim outsideSet As ObjectCollection
        If createdTotalLengthOne < createdTotalLengthTwo Then
            insideSet = createdSetOne
            outsideSet = createdSetTwo
        Else
            insideSet = createdSetTwo
            outsideSet = createdSetOne
        End If
        For Each oLine As SketchLine In insideSet
        Next
        For Each oLine As SketchLine In outsideSet
            oLine.Delete()
        Next
        Next
        oCD.Features.HoleFeatures.AddDrilledByThroughAllExtent(oPointCollection, 1, kPositiveExtentDirection)
    End If
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
https://www.freeradical.jp
benjamin.herinckx
Hi thnx for the input.
This is indeed a clever hack. Drawing both and keeping the shortest one.
However it doesn't work... which is weird.
I get the same behaviour with both pieces of code.
Does it work right on your machine ? Maybe I've got some obscure configuration wrong..
EDIT :
Fixed it, because of the DO WHILE you have to reset the length variables (otherwise it keeps adding itself)
        Dim createdTotalLengthOne As Double = 0
        Dim createdTotalLengthTwo As Double = 0
 Thank you very much !
