I'm looking for a simple way to rename a component after using the "Place Ilogic Component" command. This command does everything I need as is except for file naming. The adding of the "-1" or "-2" to the original name as it does automatically doesn't suffice for me to keep my items organized. Here's what I'm currently doing as a manual workaround.... I run the command, select my component, place it, etc. I then save my assembly and afterwords delete that item from my assembly. I then use the place command, and in the window where the items are listed find the "place ilogic" copied item and do a rename, just before double clicking to place it back into my assembly. The item that I am renaming often has child components. Those components, I leave alone and have no need for renaming, I just need to be able to find the parent model easier. Is there any way that after I place using that command, I can rename the component without deleting it. Note: I'm looking to rename the component's file name (not just the name shown in the assembly browser). I'm thinking just a simple ilogic rule which I can place as a button on my ilogic user form. Click the button, have a simple message prompt ask for the name. Something simple. As a novice programmer, I'm trign to keep everything programming-wise in iolgic as it is easy for me to use & understand.
