Control LevelOfDetail with positions and Ilogic?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi everyone, I need help,
I have learn a little bit of ilogic by myself and I managed with the forum and googles help to write (or copy and modify bits and combine) some macros to make my life easier, but I am lost now.
I have been trying for a couple of days to link the position of my assemblies with the level of detail and I can't make it work.
I have several positions called LVL1, LVL2.... and so on and levels of detail called the same, the asembly moves to the LVL1 position and I am trying that the LevelOfDetail changes automatically accordingly but it seems just impossible.
I have been searching the forum and found some code, but nothing seems to work properly. (Some rules work, but the trigger does not)
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
If oAsmCompDef.RepresentationsManager.ActiveLevelOfDetailRepresentation.Name = "LVL1" Then
oAsmCompDef.RepresentationsManager.PositionalRepresentations.Item("LVL1").Activate
Else If oAsmCompDef.RepresentationsManager.ActiveLevelOfDetailRepresentation.Name = "LVL2" Then
oAsmCompDef.RepresentationsManager.PositionalRepresentations.Item("LVL2").Activate
Else If oAsmCompDef.RepresentationsManager.ActiveLevelOfDetailRepresentation.Name = "LVL3" Then
oAsmCompDef.RepresentationsManager.PositionalRepresentations.Item("LVL3").Activate
End If
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
Dim oAsmDef As AssemblyComponentDefinition
oAsmDef = ThisApplication.ActiveDocument.ComponentDefinition
Dim oC As ComponentOccurrences
oC = oAsmDef.Occurrences
Dim oOcc As ComponentOccurrence
Dim pos As Integer
pos = 1
Dim oPosRep As PositionalRepresentation
oPosRep = oAsmDef.RepresentationsManager.PositionalRepresentations("LVL1")
For Each oOcc In oC
If pos = 1 Then
Call oPosRep.SetPositionalRepresentationOverride(oOcc, "LVL1")
pos = 0
Else
Call oPosRep.RemovePositionalRepresentationOverride(oOcc)
pos = 1
End If
Next
The first code works, (it does it's thing the other way round, I wish to activate the position to make the level of detail change, but I will be happy with that if there is no way to make it the other way) but it does not trigger automatically, I have to run the rule manually; I tried with events and nothing, then found something called "OnActivatePositionalRepresentation" wich seemed promising but I know very little of ilogic and it seems I cannot make it work.
The secong I didn't manage it to make it work at all but was somewhere in the forum as a solution...
Thanks to everyone, hope you can help me
