Content center inserting same part for different parameters
kacper_sikorskiD42JA
Message 1 of 1
I've encountered a problem with Content Center, i wanted to add with Ilogic 4parts from content center It's a simple rope and the only difference is length
After i insert sling with Wire_Diameter X the length just stays as the previous was.
I found out you can remove Content Center cache files but if i do it in Ilogic the first part inserts fine but second time i get an error
After i close and open assembly it works again.
Here's the code i've tried to make
Sub Main()
RemoveCache("Sling With Thimble")
Dim Sling_wire_Ø24_MBL_4Pos = ThisAssembly.Geometry.Point(-695.404364, 1145.249467, 177.144171)
Dim Sling_wire_Ø24_MBL_4 = Components.AddCustomContentCenterPart("Sling wire Ø24 MBL 41T:1",
        "Gleipnir Standard Parts:Slings",
        "Sling With Thimble",
        {"D_", "70", "Wire_Diameter", "24"},
        {"L_", "5000 mm"},
        asCustom := False,
        position := Sling_wire_Ø24_MBL_4Pos)
Dim Sling_wire_Ø24_MBL_4_0Pos = ThisAssembly.Geometry.Point(-1049.873622, 1350.027514, 278.837454)
Dim Sling_wire_Ø24_MBL_4_0 = Components.AddCustomContentCenterPart("Sling wire Ø24 MBL 41T:2",
        {"L_", "3000 mm"},
        asCustom := False,
        position := Sling_wire_Ø24_MBL_4_0Pos)
End Sub
Sub RemoveCache(folder As String)
' iLogic rule to delete a specific folder
	Dim folderPath As String = "D:\Documents\en-US\" & folder
	If System.IO.Directory.Exists(folderPath) Then
	    Try
	        Dim files As String() = System.IO.Directory.GetFiles(folderPath)
	        For Each filePath As String In files
	            System.IO.File.Delete(filePath)
	        Next
	        MessageBox.Show("All files deleted in folder: " & folderPath, "Success")
	    Catch ex As Exception
	        MessageBox.Show("Error deleting files: " & ex.Message, "Error")
	    End Try
	Else
	    MessageBox.Show("Folder does not exist: " & folderPath, "Info")
End Sub
Sub Main()
    ' Ensure we’re working with an assembly
    Dim doc As AssemblyDocument = TryCast(ThisApplication.ActiveDocument, AssemblyDocument)
    If doc Is Nothing Then
        MessageBox.Show("This rule only works on assembly documents.", "Error")
        Exit Sub
    ' Get full file path for reload
    Dim filePath As String = doc.FullFileName
    If String.IsNullOrEmpty(filePath) Then
        MessageBox.Show("Please save the assembly before running this rule.", "Error")
        Exit Sub
    ' Remove content center cache before first insert
    ' Insert first part
        {"L_", "5000 mm"},
        asCustom := False,
    ' Remove cache again before second insert
        {"L_", "3000 mm"},
        asCustom := False,
    ' Save, close and reopen the assembly
    doc.Save()
    doc.Close(True)
    ThisApplication.Documents.Open(filePath, True)
End Sub
        Try
            Dim files = System.IO.Directory.GetFiles(folderPath)
            Next
            MessageBox.Show("Error deleting cache files: " & ex.Message, "Cache Error")
        End Try
End Sub
Does someone know how to work around this issue? It would make things easier for me.
Thanks for all the answers in advance 😄
Replies (0)
