Connecting parts with imates by selecting the parts that i want to connect while using ilogic
X2RESTON
X2RESTON
I want to use ilogic to select two parts or subassemblies in a top level assembly and have the imates that i have entered in each automatically connect. I am new to ilogic and i am not sure this can be done
Curtis_Waguespack
@X2RESTON, here is a quick example, where both selected components have an iMate named "iMate2"
oSet = ThisApplication.ActiveDocument.CreateHighlightSet
oMsg = "Select 1st (press ESC to continue)"
Dim oOcc1 As ComponentOccurrence = ThisApplication.CommandManager.Pick _
	(SelectionFilterEnum.kAssemblyLeafOccurrenceFilter, oMsg)
' If nothing gets selected then exit
If IsNothing(oOcc1) Then Exit Sub
oSet.AddItem(oOcc1)
oMsg = "Select 2nd part (press ESC to continue)"
Dim oOcc2 As ComponentOccurrence = ThisApplication.CommandManager.Pick _
If IsNothing(oOcc2) Then Exit Sub
oSet.AddItem(oOcc2)
Constraints.AddByiMates("", oOcc1.Name,"iMate2", oOcc2.Name, "iMate2")
oSet.Clear
