Announcements
Configurator Files corrupt after about 4-6 months of operation
W_Barnett
W_Barnett
We've been developing a robust configurator that builds out one of our companies flagship products, and works as intended....until after roughly 6 months it just randomly stops working.  This has happened three times now.  Essentially, what's happening is that our configurator builds the assembly and uses one of (6x) different part files to build out the length of the assembly.  It's these 6 files that seem to be the culprit.  I believe that after N amount of rebuilds, the files start to lose functionality.  In one case, it completely corrupted and wasn't able to be opened.  The other two times, the files still worked, you could open them and generate new lengths, however trying to export data from the file to an excel file causes the program to crash.  Simply rebuilding the file from scratch and replacing it in the assembly fixed it.  This implies that there is something inherently wrong with the .ipt file itself.  Something interesting to note, the glitched file is 3x times bigger than the fresh one.
Current strategy is to back these finicky files up to a safe location, and then swap them out every 6 months (like replacing a belt on a machine after so many months of operation).
However, I was hoping that one of you guys may be able to provide an explanation to this issue, and a possible work around.  Any ideas?
A.Acheson
Can you provide a very small non confidential sample that can be tested and results in the same errors? Without a full example of the workflow and or sample to test I think there isn’t enough information in the post. Unless of course this is a very explainable behaviour.
Maybe you can send an actual sample of your work files directly to @johnsonshiue email and he can verify your findings.
Regards
Alan
W_Barnett
Can you DM his actual email, I was unable to locate it in his profile.  I'm going to scrub and identifying data from the components before I send them over.  I'll send the bloated/corrupted version and the freshly made file as a comparison.  Only thing that I can think of is that when I'm changing iProperties and Parameters, is there any chance that that data is getting stored in the part?
A.Acheson
Here is email address.  johnson.shiue@autodesk.com. He gives it out on the regular Inventor Forum
https://forums.autodesk.com/t5/inventor-forum/bd-p/78
Unfortunately this forum isn't well monitored by staff But Johnson will hopefully get it to a person who can help.
See a corruption post here.
Regards
Alan
