Compare old and new file names after Save As
Nejc.Leban
Message 1 of 33
Nejc.Leban
Hi everyone.
I would like to change some values in a document when it is saved as new file, either with Save As or Save&Replace. Let's say, I have an assembly named 12345-00-000-00 it is checked into vault and is read-only. I then save it as new file named 54321-00-000-00 to create a new product. After it saves it as a new file, I would like to automatically (without pressing any other button or running a rule manually other than Save As or Save&Replace) change the Author and Designer to current User:
ThisApplication.ActiveDocument.PropertySets.Item("Inventor Summary Information").Item("Author").Value = ThisApplication.GeneralOptions.UserName
 Does anyone know how one would get this to work?
Best regards,
Nejc
Accepted solutions (4)
Replies (32)
Message 2 of 33
Andrii_Humeniuk
Add this code to the internal rules and the rule to "Event Triggers" in the "Before Save Document" section.
Dim sName As String = ThisApplication.GeneralOptions.UserName
iProperties.Value("Summary", "Author") = sName
iProperties.Value("Project", "Designer") = sName
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
Message 3 of 33
Nejc.Leban
The file is read-only, it doesn't allow changes.
Message 4 of 33
Nejc.Leban
It also wouldn't work with Save&Replace, because
 would change the values of current active document and not the saved and replaced document.
Message 5 of 33
WCrihfield
If you need to get a reference to the 'other' document, why not use
Dim oOtherDocument As Document = ThisApplication.Documents.Open(sOtherDocumentFullDocumentName, False)
Then use similar API code to alter iProperties
oOtherDocument.PropertySets..Item("Inventor Summary Information").Item("Author").Value = ThisApplication.GeneralOptions.UserName
Wesley Crihfield
(Not an Autodesk Employee)
Message 6 of 33
Nejc.Leban
What is the value of sOtherDocumentFullDocumentName? Imagine that I perform a Save As or Save&Replace and I want to change the properties of that new saved (and replaced) file? Is there a way to get the file name from the save as dialogue window?
Message 7 of 33
WCrihfield
Sorry, been busy at work.  Since this appeared to be a code related topic, I just assumed the SaveAs action would be  done by code too, instead of with the manual process with the file dialog.  When done entirely by code, you know the file's name before you save it, and after you save it, because you had to specify the new file name.  There are events we can monitor for the regular Save and the SaveCopyAs actions, but not for the SaveAs action.  This is likely because the SaveAs action causes you to loose the reference to the 'other' document.  Below are a couple links to the events I am talking about, but I am not sure they will be of much use to you in this situation.  When properly utilizing those events, you can sometimes get useful information from the 'Context' (NameValueMap), but only the information it has available in that timing frame (before or after), and only in those two situations (Save, SaveCopyAs).
ApplicationEvents.OnSaveDocument Event
DocumentEvents.OnSave Event
Wesley Crihfield
Message 8 of 33
Nejc.Leban
Yeah, I've been at this for a while now and couldn't get a solution, so my expectations weren't too high.
Thank you for the help, I appreciate it nonetheless.
Message 9 of 33
JelteDeJong
Maybe a bit odd thought but why don't you save your 12345-00-000-00  assembly as a template? If you do that you can create new files without the problems of read-only flags. In that case, rules like the one from @Andrii_Humeniuk
Although I would use an external rule for this type of situation. It will make things simpler if you want to change the behaviour in the future
Jelte de Jong
Blog: hjalte.nl - github.com
Message 10 of 33
Frederick_Law
Might need addin which listen to OnSave event.
I have one to catch new file save by checking FileSaveCounter.
Not sure if it'll catch a SaveAs.
Code doesn't work right now.  2023 changed something.  I can't get new file name.
    Private Sub M_ApplicationEvents_OnSaveDocument(
        oDoc As _Document, BeforeOrAfter As EventTimingEnum, Context As NameValueMap,
        ByRef HandlingCode As HandlingCodeEnum) Handles M_ApplicationEvents.OnSaveDocument
      Dim oPartDoc As PartDocument
      'Cannot get new filename Before
      'Try: Check Context for file name
      If BeforeOrAfter = EventTimingEnum.kBefore Then
        'Check if new file, kAfter FileSaveCounter = 1
        If oDoc.FileSaveCounter = 0 Then
          ' MsgBox(oDoc.FullFileName)
          If oDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
            'Use Context.Item(1)
            If (InStr(oDoc.DisplayName, "Master", CompareMethod.Text) Or InStr(oDoc.DisplayName, "Layout", CompareMethod.Text)) > 0 Then
              oPartDoc = oDoc
              oPartDoc.ComponentDefinition.BOMStructure = BOMStructureEnum.kReferenceBOMStructure
              oPartDoc.ComponentDefinition.Parameters.UserParameters.Item("Length").ExposedAsProperty = False
              oPartDoc.ComponentDefinition.Parameters.UserParameters.Item("Width").ExposedAsProperty = False
              oPartDoc.ComponentDefinition.Parameters.UserParameters.Item("Area").ExposedAsProperty = False
              'IV2023: oPartDoc.Save, Save2 fire OnSave again
              'oPartDoc.Save()
    End Sub
Message 11 of 33
Andrii_Humeniuk
Hi @Nejc.Leban . You need to add this rule to external rules. Next, you need to run a read-only document and run this rule. It SaveAs your document and replaces the author and designer.
Dim oDoc As Document = ThisApplication.ActiveDocument
Dim oFileDlg As Inventor.FileDialog = Nothing
InventorVb.Application.CreateFileDialog(oFileDlg)
oFileDlg.Filter = "Inventor Files (*.iam;*.ipt)|*.iam;*.ipt|All Files (*.*)|*.*"
oFileDlg.FileName = System.IO.Path.GetFileName(oDoc.FullFileName)
oFileDlg.ShowSave()
If oFileDlg.FileName Is Nothing Or oFileDlg.FileName = "" Then Exit Sub
oDoc.SaveAs(oFileDlg.FileName, True)
If System.IO.File.Exists(oFileDlg.FileName) Then
	Dim oChildDoc As Document = ThisApplication.Documents.Open(oFileDlg.FileName, True)
	oChildDoc.PropertySets.Item("Inventor Summary Information").Item("Author").Value = sName
	oChildDoc.PropertySets.Item("Design Tracking Properties").Item("Designer").Value = sName
	oChildDoc.Save()
Message 12 of 33
yuzeaa
try this ilogic code
Class ThisRule
Private WithEvents oApplicationEvents As ApplicationEvents
Sub main
	If SharedVariable.Exists("ApplicationEvent") Then Exit Sub
	oApplicationEvents = ThisApplication.ApplicationEvents
	sharedVariable("ApplicationEvent") = oApplicationEvents
End Sub
Private Sub oAPP_onsave(DocumentObject As Document,
						ByRef HandlingCode As HandlingCodeEnum) _
						Handles oApplicationEvents.OnSaveDocument
	If BeforeOrAfter = EventTimingEnum.kBefore Then Exit Sub
	If Context(0) <> Context(1) Then
		'MsgBox(Context(1) & " was saved as " & Context(0))
		Dim doc = ThisApplication.Documents.Open(Context(0),False)
		doc.PropertySets.Item("Inventor Summary Information").Item("Author").Value = ThisApplication.GeneralOptions.UserName
End Sub
End Class
Message 13 of 33
Nejc.Leban
@JelteDeJong the problem is, I only need this when using older assemblies as reference. When starting from scratch, with a new file, it's not a problem.
@Andrii_Humeniuk thanks, but I need the code to run on the built-in SaveAs function, not a separate one.
@Frederick_Law thanks for your input, I haven't tried the code though, since @yuzeaa 's code doesn't need an add-in and it's actually working perfectly,
so thanks @yuzeaa !!
Message 14 of 33
Nejc.Leban
@yuzeaa
I would also like to change the Creation Date value to "today". When running a rule directly, this code works, but when I insert this line into your code, it only changes the Author, the date remains the same.
Dim doc = ThisApplication.ActiveDocument
'doc.PropertySets.Item("Inventor Summary Information").Item("Author").Value = ThisApplication.GeneralOptions.UserName
'doc.PropertySets.Item("Design Tracking Properties").Item("Designer").Value = ThisApplication.GeneralOptions.UserName
doc.PropertySets.Item("Design Tracking Properties").Item("Creation Time").Value = DateTime.Now.ToString("d")
 Any ideas why?
Message 15 of 33
yuzeaa
your code is right,just restart your Inventor and run the rule again.
Class ThisRule
Sub main
End Sub
	    doc.PropertySets.Item("Design Tracking Properties").Item("Creation Time").Value = DateString
End Sub
End Class
Message 16 of 33
Nejc.Leban
That's great, thank you!
Message 17 of 33
yuzeaa
Hi,@Nejc.Leban
I found some problems that this code will be triggered when you save iam file after "SaveandReplace" command  executed. the context(1) is iam file,the context(0) is ipt file . Even this cannot be detected by you.So I change my code to make sure this rule runs only when really saveas option.  You can't save A as B which B is already exists on disk.
Class ThisRule
Dim  isSaveAS As Boolean = False
Sub main
End Sub
		If Context(0) <> Context(1) AndAlso  Not IO.File.Exists(context(0)) Then isSaveAS = True  'check really saveas option
	If BeforeOrAfter = EventTimingEnum.kAfter Then
		If Not isSaveAS Then Exit Sub
		isSaveAS = False 'reset False
End Sub
End Class
Message 18 of 33
Nejc.Leban
I'm not sure I understand what you're trying to say. I've tried the code with Save&Replace and it worked exactly how I want it to work. I tried saving an assembly with Save As and it changed the values correctly. Then I inserted another assembly (let's call it SubAssembly.iam) and tried a Save&Replace on the SubAssembly.iam. I checked the SubAssembly iProperties, and the values were changed. Then I inserted a part into the main assembly (call it Part1.ipt) and tried the Save&Replace and it worked fine there too.
Message 19 of 33
yuzeaa
After you saveandreplace A to B in iam file ,when you save iam file everytime, the rule fires again and B'properties changed  once again .If you saveandreplace 10 ipt files,this rule will executed 10 times  every time you save iam file which is not needed.  So I said you can not detect this mistake because the result of B'properties always right.You can cancel the following comment  in rule  and see how and when the rule runs.
Message 20 of 33
Nejc.Leban
OK, thank you.
I ran into another problem though... I have this rule in an external rules folder and set to run Before Save Document. It works great for what I want, but when I'm working with Frame Generator and I insert Frame on 2 sketch lines with same lengths, I get an error: "A frame member could not be created. The template file for DIN 2395 ... structural steel could not be located in the Content Center library. If I don't run your rule, everything works fine like before.
Do you maybe have a solution for that or do you know why it happens?
