Command doesn't get executed
fakeru
fakeru
I'm trying to invoke a command execution, but without any success.
Dim oCopyControlDef As ControlDefinition
    Set oCopyControlDef = ThisApplication.CommandManager.ControlDefinitions.Item("PartMoveFaceCmd")
    oCopyControlDef.Execute
I run this code when I have a part open. I tried to select a face before running the conde, but still doesn't show up...
Any ideas why?
Alexandru
Autodesk Inventor 2015 Certified Professional
CadUser46
Fakeru.  I never realised this until now but the move face command has been retired, at least in 2016.  Its still listed in the control definitions i guess as a legacy command but its been replaced with PartDirectCmd.
Public Sub MoveFace()
    Call ThisApplication.CommandManager.ControlDefinitions.Item("PartDirectCmd").Execute
End Sub
Inventor 2010 Certified Professional
Currently using 2023 Pro
fakeru
thanks forhe info. I guess I will have to stick with DirectEdit, although I would prefer moveface command.
