COLOR CHANGE FOLDING LINE
analistacad
analistacad
Hi friends
Can someone help me, how to create an ilogic rule to change the double lines UP BLUE and DOWN RED in Inventor planes?
I WANT THE LINE TO ALSO CHANGE COLOR
JelteDeJong
Maybe this is what you need:
Sub Main()
    Dim doc As DrawingDocument = ThisDoc.Document
    ChangeLayer(doc, DrawingEdgeTypeEnum.kBendUpEdge, "ARRIBA")
    ChangeLayer(doc, DrawingEdgeTypeEnum.kBendDownEdge, "ABAJO")
End Sub
Private Sub ChangeLayer(doc As DrawingDocument, EdgeType As DrawingEdgeTypeEnum, layerName As String)
    Dim layer As Layer = doc.StylesManager.Layers.Item(layerName)
    Dim segments = doc.Sheets.Cast(Of Sheet).
        SelectMany(Function(sheet) sheet.DrawingViews.Cast(Of DrawingView)).
        SelectMany(Function(view) view.DrawingCurves.Cast(Of DrawingCurve)).
        Where(Function(curve) curve.EdgeType = EdgeType).
        SelectMany(Function(curve) curve.Segments.Cast(Of DrawingCurveSegment)).
        ToList()
    For Each segment As DrawingCurveSegment In segments
        segment.Layer = layer
    Next
End Sub
Edit:
improved the rule
Jelte de Jong
Blog: hjalte.nl - github.com
analistacad
Uff !!! Excellent work friend !! Thanks
- A question for version 2017 is it possible?
- It is possible to leave a single rule see image
- What should I study to have ilogic proficiency?
Thanks friend Great help a greeting from
Colombia  😃🙏🤝
analistacad
Hello
Friend Jelte DeJong
I get this error, see image
Error in rule 3, in document: SER1-00-A00.idw
Cannot find the public member "Cast" in the type Sheets
greeting
JelteDeJong
In the code, I use the LINQ library. I'm not sure if that library is already available in Inventor 2017.  This is the same rule only without the helper functions from the LINQ library.
Sub Main()
End Sub
    For Each sheet As Sheet In doc.Sheets
        For Each view As DrawingView In Sheet.DrawingViews
            For Each curve As DrawingCurve In View.DrawingCurves
                If (curve.EdgeType = EdgeType) Then
                    For Each segment As DrawingCurveSegment In curve.Segments
                    Next
                End If
            Next
        Next
    Next
End Sub
Jelte de Jong
analistacad
Friend, I am very grateful to you, thank you very much, it already worked for me!😃
from Colombia a cordial greeting
analistacad
