Coding style: What do you think is better?
- Mute
- Permalink
- Report
I have 4 rules that do exactly the same thing. Just out of curiosity I would like to know what you think is the best code snippet? Should the code be as short as possible and what about readability?
Snippet 1:
Dim view As DrawingView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select a drawing view")
If (view Is Nothing) Then Return
view.DrawingCurves.Cast(Of DrawingCurve).Where(Function(c) c.EdgeType = DrawingEdgeTypeEnum.kBendDownEdge Or c.EdgeType = DrawingEdgeTypeEnum.kBendUpEdge).ToList().ForEach(Function(c) view.Parent.DrawingNotes.BendNotes.Add(c))
Snippet 2:
Snippet 3:
Dim bendCurves = view.DrawingCurves.Cast(Of DrawingCurve).
Where(Function(curve) curve.EdgeType = DrawingEdgeTypeEnum.kBendDownEdge Or
curve.EdgeType = DrawingEdgeTypeEnum.kBendUpEdge).ToList()
Dim bendNotes = view.Parent.DrawingNotes.BendNotes
For Each curve As DrawingCurve In bendCurves
bendNotes.Add(curve)
Next
Snippet 4:
' Let the user select the view that he/she wants to update.
Dim commandManager As CommandManager = ThisApplication.CommandManager
Dim view As DrawingView = commandManager.Pick(
' Check if the user selected a view.
' If not stop the rule.
Return
End If
' Create a list of all bend cures
Dim bendCUrves As List(Of DrawingCurve)
bendCUrves = New List(Of DrawingCurve)
For Each curve As DrawingCurve In view.DrawingCurves
If (curve.EdgeType = DrawingEdgeTypeEnum.kBendDownEdge) Then
bendCUrves.Add(curve)
End If
If (curve.EdgeType = DrawingEdgeTypeEnum.kBendUpEdge) Then
End If
Next
' Add bend notes to all sheets.
Dim sheet As Sheet = view.Parent
Dim bendNotes = sheet.DrawingNotes.BendNotes
For Each curve As DrawingCurve In bendCUrves
Next
Jelte de Jong
Blog: hjalte.nl - github.com
