Code to delete <SCALE> from Edit View Label
Hi all,
I would like to delete Scale from all views on my sheet. Now I have to erase it manually and it takes a lot of time as I have to do this on hundreds of drawings.
Any way to do this in iLogic? I found a thread with something similar, however I'm new to iLogic and could not find a way to edit the code to make it work for deleting Scale.
https://forums.autodesk.com/t5/inventor-customization/custom-user-properties-in-view-label-of-drawin...
Thanks.
JhoelForshav
Hi @Anonymous
Try running this rule in your drawing 🙂
For Each oSheet As Sheet In ThisDrawing.Document.Sheets
	For Each oView As DrawingView In oSheet.DrawingViews
		oView.Label.FormattedText = oView.Label.FormattedText.Replace("<DrawingViewScale/>", "")
	Next
Next
Works perfectly!
However I forgot to mention that I also want to delete the parentheses before and after SCLAE. Format text now look like this: <VIEW>-<VIEW> ( <SCALE> )
I guess this is a simple fix but I'm not familiar with this coding language.
JhoelForshav
Anyone of these options should work then 🙂
		oView.Label.FormattedText = oView.Label.FormattedText.Replace("<DrawingViewScale/>", "").Replace("(", "").Replace(")", "")
	Next
Next
Or
		oView.Label.FormattedText = "<DrawingViewName/>-<DrawingViewName/>"
	Next
Next
Thanks!!
