Code issue - Modify multiple idw documents title blocks prompt entries
EduLourenco
EduLourenco
Hello all,
I'm having an issue with "my" code, which doesn't allow me to change the prompts in multiple title blocks.
What happens now:
I've a 2D drawing with title block already filled with information, all this information is prompted entry. And lots of idw follow the same structure.
Then if i want to reuse these drawings for another project which has different numbering (in this case "Nrº Obra" and "Codificação EQ"), i have to open one by one, change it and print it to PDF file.
What i would like to happen (if possible):
I would like to open multiple idw documents and run a rule which  allows me to change the two prompt entries as i said above and it changes to all opened idw documents and print them.
I've found a code that allows me to print all the documents that i have open in inventor (link to original below)
https://magazine.thingimajigs.com/autodesk-inventor-batch-exporting-pdfs-dxfs-with-ilogic/
And now i've added one sub "Substitui_Legenda" (got if from somewhere also) to go and replace the prompts entry on the title block. But it only works on the idw that i've currently open, and doesnt replace on the others (i've tried on documents with the same title block to see if it was a title block issue)
If someone can help me with this or tell me if it is possible as i don't really have much experience with ilogic. See the code below.
During selection it says excel but it isnt currently running.
And sorry for the half english and half portuguese typing on the code
Sub Main
	Dim myDate As String = Now().ToString("dd-MM-yyyy")
	myDate = myDate.Replace(":","")  ' & " - " & TypeString
	userChoice = InputRadioBox("Defined the scope", "This Document", "All Open Documents", True, Title := "Defined the scope")
	UserSelectedActionList = New String(){"DWG & PDF & Excel", "PDF Only", "PDF & Excel"}
	UserSelectedAction = InputListBox("What action must be performed with selected views?", _
	      UserSelectedActionList, UserSelectedActionList(0), Title := "Action to Perform", ListName := "Options")
	Select UserSelectedAction
		Case "DWG & PDF & Excel": UserSelectedAction = 3
		Case "PDF Only": UserSelectedAction = 1
		Case "PDF & Excel":    UserSelectedAction = 2
	End Select
	' Insere novos dados na legenda
	SharedVariable("pNrº Obra") = InputBox("Escolher Numero de Obra", "Numbero de Obra")
	SharedVariable("pCodificação_EQ") = InputBox("Escolher Codificação", "Codificação")
	Call Substitui_Legenda
	If userChoice Then
			Call MakePDFFromDoc(ThisApplication.ActiveDocument, myDate, UserSelectedAction)
		Else
		For Each oDoc In ThisApplication.Documents
			If oDoc.DocumentType = kDrawingDocumentObject
				Try
				  	If Len(oDoc.File.FullFileName) >0 Then
				   		Call MakePDFFromDoc(oDoc, myDate, UserSelectedAction)
				Catch
				End Try
		Next
End Sub
Sub MakePDFFromDoc(ByRef oDocument As Document, DateString As String, UserSelectedAction As Integer)
	' oPath = oDocument.Path
	' oFileName = oDocument.FileName(False) 'without extension
	'oDocument = ThisApplication.ActiveDocument
	oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _
	("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
	oContext = ThisApplication.TransientObjects.CreateTranslationContext
	oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
	oOptions = ThisApplication.TransientObjects.CreateNameValueMap
	oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
	oFullFileName = oDocument.File.FullFileName
	oPath = Left(oFullFileName, InStrRev(oFullFileName, "\")-1)
	oFileName = Right(oFullFileName, Len(oFullFileName)-InStrRev(oFullFileName, "\"))
	oFilePart = Left(oFileName, InStrRev(oFileName, ".")-1)
	'oRevNum = oDocument.iProperties.Value("Project", "Revision Number")
	' If oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then
	oOptions.Value("All_Color_AS_Black") = 0
	oOptions.Value("Remove_Line_Weights") = 0
	oOptions.Value("Vector_Resolution") = 400
	oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
	'oOptions.Value("Custom_Begin_Sheet") = 2
	'oOptions.Value("Custom_End_Sheet") = 4
	' End If
	'get PDF target folder path
	'oFolder = Left(oPath, InStrRev(oPath, "\")) & "PDF"
	'  oFolder = oPath & "\Dokumentace(" & DateString & ")"
	oFolder = oPath & "\" & oFilePart
	oDirectoryName = System.IO.Path.GetDirectoryName(oFullFileName)
	'Check for the PDF folder and create it if it does not exist
	If Not System.IO.Directory.Exists(oFolder) Then
		System.IO.Directory.CreateDirectory(oFolder)
	'Set the PDF target file name
	oDataMedium.FileName = oFolder & "\" & oFilePart & ".pdf"
	'Publish document
	If (UserSelectedAction = 1) Then
		oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)'For PDF's
		oDocument.SaveAs(oFolder & "\" & oFilePart & ".dwg", True) 'For DWG's
	If (UserSelectedAction = 2) Then
	If (UserSelectedAction = 3) Then
	'oDocument.SaveAs(oFolder & "\" & ThisDoc.ChangeExtension(".DWG"), True) 'For DWG's
	'------end of iLogic-------
 End Sub
 ' Modifica a legenda com base na informações fornecidas
Sub Substitui_Legenda
	'Read Title Block from Active Sheet
	Dim oDoc As Document
	oDoc = ThisApplication.ActiveDocument
	Dim oSheet As Sheet
	oSheet = oDoc.ActiveSheet
	Dim oTB1 As TitleBlock
	oTB1 = oSheet.TitleBlock
	Dim titleDef As TitleBlockDefinition
	titleDef = oTB1.Definition
	Dim oPrompt1 As Inventor.TextBox
	Dim oPrompt2 As Inventor.TextBox
	Dim oPrompt3 As Inventor.TextBox
	Dim oPrompt4 As Inventor.TextBox
	Dim oPrompt5 As Inventor.TextBox
	Dim oPrompt6 As Inventor.TextBox
	Dim oPrompt7 As Inventor.TextBox
	Dim oPrompt8 As Inventor.TextBox
	'make sure you declare all your prompts
	' Find the Prompted Entry in the Title Block
	For Each defText As Inventor.TextBox In titleDef.Sketch.TextBoxes
		On Error Resume Next
		If defText.Text = "Obra / Desginacao Projecto" Then
			oPrompt1 = defText
		ElseIf defText.Text = "Nrº Obra" Then
			oPrompt2 = defText
		ElseIf defText.Text = "Codificação EQ" Then
			oPrompt3 = defText
		ElseIf defText.Text = "Nrº Série" Then
			oPrompt4 = defText
		ElseIf defText.Text = "Titulo" Then
			oPrompt5 = defText
		ElseIf defText.Text = "Area" Then
			oPrompt6 = defText
		ElseIf defText.Text = "Categoria" Then
			oPrompt7 = defText
		ElseIf defText.Text = "Numero" Then
			oPrompt8 = defText
	Next
	oTB1.SetPromptResultText(oPrompt2, SharedVariable("pNrº Obra"))
	oTB1.SetPromptResultText(oPrompt3, SharedVariable("pCodificação_EQ"))
	SharedVariable.Remove("pNrº Obra")
	SharedVariable.Remove("pCodificação_EQ")
End Sub
Thanks in advance
C_Haines_ENG
When cycling through all open documents in the fashion of a "For - Next" loop, you are not actually "activating" each document. However your code is ONLY running on the active document, its not even attached to the For loop.
Try this simplified code below:
Sub Main
	For Each oDoc As Document In ThisApplication.Documents.VisibleDocuments
		If oDoc.DocumentType <> kDrawingDocumentObject Then Continue For
		Dim oTitleBlock As TitleBlock = oDoc.Sheets(1).TitleBlock
		For Each oTextBox As TextBox In oTitleBlock.Definition.Sketch.TextBoxes
			If oTextBox.Text = "Obra / Desginacao Projecto"
				oTitleBlock.SetPromptResultText(oTextBox, "Did this work?")
		Next
	Next
End Sub
EduLourenco
Yes it worked like a charm thank you so much!!!
