Code creating extra folder when saving STEP files
steve_lindley
steve_lindley
Hi all,
Using Inventor Pro 2025.0.1
We have an ilogic rule for saving out dxf, pdf and step files, which we run only from inside a dwg of a sheet metal ipt that has folds. We've had the rule a while and it's been proven but recently I was asked to modify it to include the revision number on the end of the file names when saved.
What I've got works, but there's one niggle I'd like to iron out.
When it saves the step file, it is creating an extra folder and saving the step file in there. To clarify with an example, lets say I have a dwg named CT10-341 and an ipt of the same name.
The dxf and pdf both save to this path: V:\3D Data\DXF\Design Office dxfs - Steves\CT10-341 REV 2 (.dxf and .pdf accordingly).
However, the STEP file is saving to this path: V:\3D Data\DXF\Design Office dxfs - Steves\CT10-341\CT10-341 REV 2.stp
I'm a total amateur with ilogic and haven't any real experience of coding. Generally I copy code from what I find on here, so I don't always understand what's going on I'm afraid! I recognise that I'm defining the path by using the filename without extension and then asking for the new file to use that path and add the new filename with revision.
strFolder = "V:\3D Data\DXF\Design Office dxfs - Steves\" & ThisDoc.FileName(False) 'without extension
	ThisDoc.Document.SaveAs(strFolder & (" REV ") & sRevNumb & (".pdf"), True)
	ThisDoc.Document.SaveAs(strFolder & (" REV ") & sRevNumb & (".dxf"), True)
That same code works for both the dxf and pdf sections but if I try it with the STEP file, it throws an error, pointing to the final STEPTranslator line:
		ThisDoc.Document.SaveAs(strFolder & (" REV ") & sRevNumb & (".stp"), True)
I figured out that this works:
		oData.FileName = strFolder & oStepFileName & " REV " & sRevNumb & ".stp"
But it doubles up the filename. In the example above my new step file is named CT10-341CT10-341 REV 2.stp.
So I now have this, which gives me that extra folder level.
		oData.FileName = strFolder & "\" & oStepFileName & " REV " & sRevNumb & ".stp"
If anyone can point me in the right direction please, I'd be grateful. Please see my complete code below.
'Declare using subroutines and define the start of the Main section of code
Sub Main()
'---------------------------------------Below code checks the Part Number iProperty against the FileName---------
oDoc = ThisDoc.FileName(False)
PartNumber = iProperties.Value("Project", "Part Number")
If oDoc = PartNumber Then
	Call Saving()
Else
	Try
		oProp = iProperties.Value("Custom", "NotFileName")
		Return
	Return
	Catch
		i = MessageBox.Show("Drawing iProperty Part Number does NOT match filename. Would you like it to match?","My iLogic Dialog",MessageBoxButtons.YesNo,MessageBoxIcon.Hand ,MessageBoxDefaultButton.Button1)
		If i = MsgBoxResult.Yes Then
			iProperties.Value("Project", "Part Number") = oDoc
			Call DeleteCustomiProp()
			Call Saving()
		ElseIf i = MsgBoxResult.No Then
			iProperties.Value("Custom", "NotFileName") = "No"
			Call Saving()
	End Try
'Define the end of the Main section of code
End Sub
Sub DeleteCustomiProp()
'define list of custom properties to delete
Dim MyArrayList As New ArrayList
MyArrayList.Add("NotFileName")
'define custom property collection
oCustomPropertySet = ThisDoc.Document.PropertySets.Item("Inventor User Defined Properties")
'look at each property in the collection
For Each oCustProp In oCustomPropertySet
'check property name against the list you want to delete
	If MyArrayList.Contains(oCustProp.name)Then
	'delete the custom iProperty
	oCustProp.Delete
	Else
	'skip it
Next
End Sub
Sub Saving()
'Activate Sheet 1 for creating pdf
ActiveSheet = ThisDrawing.Sheet("Sheet:1")
Dim oDraw As DrawingDocument = ThisDoc.Document
If TypeOf oDraw.AllReferencedDocuments.Item(1) Is PartDocument Then
	Dim oDoc1 As PartDocument = oDraw.AllReferencedDocuments.Item(1)
	Dim sRevNumb As String = oDoc1.PropertySets.Item("Inventor Summary Information").Item("Revision Number").Expression
'Make sure 2nd sheet is named "FLAT" to enable save copy as dxf
Dim sInput1 As String
sInput1 = "FLAT"
Dim sInput2 As String
sInput2 = "DXF"
Dim sShName As String
Dim sShNum As String
Dim oSheet As Sheet
Dim lPos As Long
Dim lLen As Long
For Each oSheet In ThisApplication.ActiveDocument.Sheets
   lPos = InStr(oSheet.Name, ":") 'position of the colon
   lLen = Len(oSheet.Name) 'length of sheet name
   sShName = Left(oSheet.Name, lPos -1) 'string left of the colon
   sShNum = Right(oSheet.Name, lLen -lPos ) 'string right of the colon
          If sShNum = 2 Then
          oSheet.Name = sInput1
Next
'Activate Sheet 2, which should have the dxf on
ActiveSheet = ThisDrawing.Sheet("FLAT:2")
' Set a reference to the drawing document.
' This assumes a drawing document is active.
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
' Set a reference to the active sheet.
Dim oActiveSheet As Sheet
oActiveSheet = oDrawDoc.ActiveSheet
'get 1st view on active sheet
Dim oView As DrawingView
oView = oActiveSheet.DrawingViews(1)
'set view scale to 1:1
ActiveSheet.View(oView.Name).Scale = 1
'add a margin value
oMargin = 100.0 'mm
'get width,
'and add margin
Dim oWidth As Double
oWidth = (ActiveSheet.View(oView.Name).Width) + oMargin
'get Height,
'and add margin
Dim oHeight As Double
oHeight = (ActiveSheet.View(oView.Name).Height) + oMargin
If oView.Width < oView.Height Then
    'resize the view
    ActiveSheet.ChangeSize(oWidth, oHeight , moveBorderItems := True)
    'center the view
    ActiveSheet.View(oView.Name).SetCenter(oWidth/2,oHeight/2)
    'change sheet Orientation
    ThisApplication.ActiveDocument.ActiveSheet.Orientation  = _
    PageOrientationTypeEnum.kPortraitPageOrientation
Else If oView.Height < oView.Width Then
    'resize the view
    ActiveSheet.ChangeSize(oHeight, oWidth, moveBorderItems := True)
    'center the view
    PageOrientationTypeEnum.kLandscapePageOrientation
Else
    'width and height are equal
    'resize the view
    ActiveSheet.ChangeSize(oHeight, oHeight, moveBorderItems := True)
    'center the view
    ActiveSheet.View(oView.Name).SetCenter(oHeight/2, oHeight/2)
'zoom all
ThisApplication.ActiveView.Fit
Dim oDraw1 As DrawingDocument = ThisDoc.Document
If TypeOf oDraw1.AllReferencedDocuments.Item(1) Is PartDocument Then
	Dim oDoc1 As PartDocument = oDraw1.AllReferencedDocuments.Item(1)
	'Save copy as dxf into dxf folder
'Activate Sheet 1 before closing
ThisApplication.CommandManager.ControlDefinitions.Item("AppZoomallCmd").Execute
'------------------------End of pdf and dxf creation-------------------------------------
'Dim statement: Declares and allocates storage space for variables
Dim oPart As Inventor.PartDocument
'Using this active drawing document
oDrawingDoc = ThisDrawing.Document
'Using this active sheet
oSheet = ActiveSheet.Sheet
'Using the first view in this drawing sheet
oDrawingView = oSheet.DrawingViews(1)
If ActiveSheet.View(oDrawingView.Name).ModelDocument.DocumentType = Inventor.DocumentTypeEnum.kPartDocumentObject Then
'Using the part in this first view
oPart = ActiveSheet.View(oDrawingView.Name).ModelDocument
'Assuming part and drawing share the same file name
NewFileName = ThisDoc.ChangeExtension(".ipt")
'Open the part seperately
ThisApplication.Documents.Open(NewFileName, True)
If oPart.DocumentType = kPartDocumentObject Then 'Confirm Part
	If oPart.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
   		' Get the STEP translator Add-In.
		Dim oSTEPTranslator As TranslatorAddIn
		oSTEPTranslator = ThisApplication.ApplicationAddIns.ItemById("{90AF7F40-0C01-11D5-8E83-0010B541CD80}")
		Dim oContext As TranslationContext
		oContext = ThisApplication.TransientObjects.CreateTranslationContext
		Dim oOptions As NameValueMap
		oOptions = ThisApplication.TransientObjects.CreateNameValueMap
		oStepFileName = iProperties.Value("Project", "Part Number")
If oSTEPTranslator.HasSaveCopyAsOptions(ThisApplication.ActiveDocument, oContext, oOptions) Then
    ' Set application protocol.
    ' 2 = AP 203 - Configuration Controlled Design
    ' 3 = AP 214 - Automotive Design
    oOptions.Value("ApplicationProtocolType") = 2
    ' Other options...
    'oOptions.Value("Author") = ""
    'oOptions.Value("Authorization") = ""
    'oOptions.Value("Description") = ""
    'oOptions.Value("Organization") = ""
    oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
    Dim oData As DataMedium
    oData = ThisApplication.TransientObjects.CreateDataMedium
	Dim oDraw2 As DrawingDocument = ThisDoc.Document
	If TypeOf oDraw2.AllReferencedDocuments.Item(1) Is PartDocument Then
		Dim oDoc2 As PartDocument = oDraw2.AllReferencedDocuments.Item(1)
		Dim sRevNumb As String = oDoc2.PropertySets.Item("Inventor Summary Information").Item("Revision Number").Expression
		'oData.FileName = strFolder & oStepFileName & " REV " & sRevNumb & ".stp"
		'ThisDoc.Document.SaveAs(strFolder & (" REV ") & sRevNumb & (".stp"), True)
'	strFolder = "V:\3D Data\DXF\Design Office dxfs - Steves\"
'    oData.FileName = strFolder & "\" & oStepFileName & ".stp"
    oSTEPTranslator.SaveCopyAs(ThisApplication.ActiveDocument, oContext, oOptions, oData)
	Else 'Confirm Standard
	MessageBox.Show("Not a sheet metal part - No STEP file saved", "Check: Is this sheet metal?")
	ThisApplication.CommandManager.ControlDefinitions.Item("AppFileCloseCmd").Execute
'Gives Feedback to User
MessageBox.Show("Rule completed", "File Save")
End Sub
vpeuvion
Hi, can you try this :
		strFolder = "V:\3D Data\DXF\Design Office dxfs - Steves\"  'without extension
		'OR
		oData.FileName = strFolder & ThisDoc.FileName(False) & " REV " & sRevNumb & ".stp"
Vincent.
steve_lindley
@vpeuvion Sorry for not replying sooner but that top suggestion solves it. Thank you!
