Client Graphics on drawing, position based on part location within view
jdasilvaS39UQ
jdasilvaS39UQ
Hi, I am trying to highlight components on a drawing view as solid red using client graphics. I am using the componentoccurrence of the assembly in the drawing view to create surfacegraphics and display that. It is working where it will display what i was expecting but I am stuck trying to position it, it defaults to the center of the view. I can move it with SetTransformBehavior but I can't get an accurate position based on the part itself.
So my question is how do we get the part origin point in drawing/drawing view space using a componentoccurrence
This loops through each view
For Each oDrawingView In sparesSheet.DrawingViews
		Try
			oDataSets = oDrawingView.GraphicsDataSetsCollection.Item("CG_Test3")
			oDataSets.Delete
			oDataSets = oDrawingView.GraphicsDataSetsCollection.Add("CG_Test3")
		Catch
		End Try
		Try
			oClientGraphics = oDrawingView.ClientGraphicsCollection.Item("CG_Test3")
			oClientGraphics.Delete
			oClientGraphics = oDrawingView.ClientGraphicsCollection.Add("CG_Test3")
		Catch
		End Try
		Dim oModelDoc As Document
		oModelDoc = oDrawingView.ReferencedDocumentDescriptor.ReferencedDocument
		TraverseAssembly(oModelDoc.ComponentDefinition.Occurrences)
		iLogicVb.UpdateWhenDone = True
	Next
Here is the part actually creating client graphics within the traverseassembly loop
			Dim oLineNode As GraphicsNode
			oLineNode = oClientGraphics.AddNode(1)
			Dim oTransientBRep As TransientBRep
			oTransientBRep = ThisApplication.TransientBRep
			 'By Transient Brep Class To copy the surface body
			  Dim oBody As SurfaceBody
			  oBody = oTransientBRep.Copy(oOcc.Definition.SurfaceBodies.Item(1))
			  ' Create client graphics based on the transient body
			  Dim oSurfaceGraphics As SurfaceGraphics
			  oSurfaceGraphics = oLineNode.AddSurfaceGraphics(oBody)
				oSurfaceGraphics.Color = oColor
				oSurfaceGraphics.BurnThrough = True
				'oSurfaceGraphics.SetViewSpaceAnchor(oTG.CreatePoint(0,0,0), oTG.CreatePoint2d(10,10), ViewLayoutEnum.kBottomLeftViewCorner)
				Dim temp As WorkPoint
				temp = oOcc.Definition.WorkPoints(1)
				Dim tempproxy As WorkPointProxy
				oOcc.CreateGeometryProxy(temp, tempproxy)
				oSurfaceGraphics.SetTransformBehavior(oTg.CreatePoint(tempproxy.Point.X, tempproxy.Point.Y, tempproxy.Point.Z), DisplayTransformBehaviorEnum.kFrontFacing)
jdasilvaS39UQ
I was able to figure it out. I got the transformation of the occurrence in the assembly and combined it with the transform of the assembly within the view and set the graphics node transform to that and it worked perfect.
			Dim oOccPtInAssem As Matrix
			oOccPtInAssem = oOcc.Transformation
			Dim oAssemPtInView As Matrix
			oAssemPtInView = oDrawingView.ModelToDrawingViewTransform
			oOccPtInAssem.PreMultiplyBy(oAssemPtInView)
			oLineNode.Transformation = oOccPtInAssem
