Check Sketch with Feature
The following problem occurs in my automation process.
In my case some of the sketch closed entities are not converted as solid while using extrude feature.
So some cuts are missing.
I need to confirm whether all the closed entities are converted as solid. Otherwise i need to show user about the extrude feature conversion error.
Guide me how to identify whether all the closed profiles are converted as Solid?
dutt.thakar
Hello @Anonymous ,
If you just want to check whether your sketch is owned by feature or not below code will work, if you have open profile sketch and still it is consumed by extrude surface, it will not be shown using below code. it will only show the sketches that are orphan (i.e. not used in any feature).
Dim oDoc As PartDocument = ThisApplication.ActiveDocument
Dim oDef As PartComponentDefinition = oDoc.ComponentDefinition
Dim oSketch As PlanarSketch
For Each oSketch In oDef.Sketches
	If oSketch.IsOwnedByFeature= True   ' You can use oSketch.Consumed = False as well to check here.
		MessageBox.Show(oSketch.Name")
	End If
Next
If this has answered your question, please accept this as solution.
Dutt Thakar
If this answer has solved your problem please ACCEPT SOLUTION and hit like if you found it helpful..!
Dutt Thakar
LinkedIn
WCrihfield
You should study the contents of this link.  It describes the Function "AddForSolid()" used to prepare a sketche's profiles for an extrusion feature.
Profiles.AddForSolid Method
Wesley Crihfield
(Not an Autodesk Employee)
