Check part description fx linked or not
k14348
k14348
    I have a main assembly with 10 No. of parts. I would like to check all 10 Parts description starts with = or not. If Description not starts with = sign then i need that file name list.
Karth
JelteDeJong
you can try this.
Dim notLinkedList As String = ""
Dim AssDoc As AssemblyDocument = ThisDoc.Document
For Each doc As Document In AssDoc.ReferencedDocuments
    Dim oPropSets As PropertySets = doc.PropertySets
    Dim oPropSet As PropertySet = oPropSets.Item("Design Tracking Properties")
    Dim oPartNumiProp As Inventor.Property = oPropSet.Item("Description")
    If (oPartNumiProp.Expression = Nothing) Then
        notLinkedList = notLinkedList + doc.FullFileName + System.Environment.NewLine
        Continue For
    End If
    If (oPartNumiProp.Expression.StartsWith("=") = False) Then
    End If
Next
MsgBox(notLinkedList)
Jelte de Jong
Blog: hjalte.nl - github.com
k14348
   Thanks for your reply. As i know only vba i expect this coding in vba. Thanks for understanding.
Karth
k14348
   Can anybody correct this code to open the partDocument. If "=" sign not there.
Option Explicit
Sub DescriptCheck()
    Dim oApp As Application
    Set oApp = ThisApplication
    Dim oAsmDoc As AssemblyDocument
    Set oAsmDoc = oApp.ActiveDocument
    Dim oPartDoc As PartDocument
    Dim oProp As Property
    For Each oPartDoc In oAsmDoc.AllReferencedDocuments
    Set oProp = oPartDoc.PropertySets.Item("Design Tracking Properties").Item("Description")
    Dim oVal As Variant
    oVal = oProp.Expression
    MsgBox (oVal)
    If Left(oVal, 1) = "=" Then
    MsgBox ("yes")
    Else
    'oPartDoc.Open I need this line to open the doc
    End If
    Next
End Sub
WCrihfield
I think the line you're looking for is:
Call ThisApplication.Documents.Open(oPartDoc.FullFileName, True)
'Or in your case
Call oApp.Documents.Open(oPartDoc.FullFileName, True)
I hope this helps.
If this solves your problem, or answers your questions, please click 'Accept As Solution".
Or, if this helps you reach your goal, please click 'LIKES" :thumbs_up:.
Also, if you're interested, here are a few of the 'Ideas' I'd like to get implemented.
If you agree with any of them, please vote for them.
  • Add more capabilities to the 'Customize' dialog box (exe. Add Tab & Add Panel) Click Here
  • MessageBox, InputBox, and InputListBox Size & Format Options Click Here
  • Constrain & Dimension Images In Assembly Sketches & Drawing Sketches (TitleBlocks & SketchedSymbols) Click Here
  • Save Section View Status In DesignViewRepresentation (So It Can Be Used In The Drawing) Click Here
  • Add SolidBodies Folder In iLogic Rule Editor Model Tab Click Here
  • Convert All Views To Raster Before Autosave Stores To 'OldVersions' Folder Click Here
  • SetDesignViewRepresentation - Fix limitations for DrawingView of a Part Click Here
Inventor 2020 Help | Inventor Forum | Inventor Customization Forum | Inventor Ideas Forum
Wesley Crihfield
(Not an Autodesk Employee)
