Check-in sequence
Check-in sequence
lstarke
Check-in sequence
lstarke
Hi ppl,
Someone can explain why in diferent cases I have diferente check-in sequences ? See images attached.
check-in1.png shows a check-in sequence that before I execute my addin code.
check-in2.png shows a diferent check-in sequence that I did the same steps that my addin did but manually.
Obs: Part13.ipt has a link to Part13.ipt - Edgecam.ipt
If someone can help...
wayne.brill
Please provide a small but complete Visual Studio project that I can use to research this behavior.
(Please keep in mind that using the Vault API to check in an Inventor file is not supported).
Wayne
Wayne Brill
Developer Technical Services
Autodesk Developer Network
