Announcements
Check if part is on workspace if not then download from vault (iLogic)
KenVaessen
KenVaessen
Is there an iLogic code that I can implement that checks if a part is on my workspace. If not then download this file from the vault
Replies (11)
bradeneuropeArthur
Public Sub main()
Dim a As Application
Set a = ThisApplication
Dim CmdMan As ControlDefinition
    Set CmdMan = ThisApplication.CommandManager.ControlDefinitions.Item("VaultCheckout")
    If CmdMan.Enabled = True Then
    CmdMan.Execute
        'CmdMan.Execute2 (True)
End Sub
Arthur Knoors
Autodesk Affiliations:
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
bradeneuropeArthur
Modified the last post....
Arthur Knoors
KenVaessen
I got the next error when I run this rule in iLogic:
Rule Compile Errors in Rule0, in afvoerbuis test samenstelling.iam
Error on Line 4 : Let- en Set-assignment instructions are no longer supported.
Error on Line 7 : Let- en Set-assignment instructions are no longer supported.
bradeneuropeArthur
Public Sub main()
 a = ThisApplication
CmdMan.Execute 'CmdMan.Execute2 (True)
End Sub
Arthur Knoors
KenVaessen
I've deleted the part in my workspace and runned the rule you wrote.
But he doesn't download the file from the vault (see attachment).
bradeneuropeArthur
Set you project to straight VBA code
Arthur Knoors
KenVaessen
How do I do that exactly?
bradeneuropeArthur
Is your Vault activated within inventor?
Arthur Knoors
KenVaessen
yes it's active
bradeneuropeArthur
try it in a different way:
For VBA:
Public Sub main()
set a = ThisApplication
set CmdMan = ThisApplication.CommandManager.ControlDefinitions.Item("VaultCheckoutTop")
MsgBox "will be checked out"
End Sub
For I logic
Public Sub Main()
a = ThisApplication
MsgBox ("will be checked out")
End Sub
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
KenVaessen
Still doesn't work. So I've  checked the assy out of the vault. I saved the assy to my workspace and all the parts are in the directory. Now I start the assy out of my workspace and I delete a part in this directory on the workspace. If I run the rule the part doesn't return in my workspace directory.
