try it in a different way:
For VBA:
Public Sub main()
Dim a As Application
set a = ThisApplication
Dim CmdMan As ControlDefinition
set CmdMan = ThisApplication.CommandManager.ControlDefinitions.Item("VaultCheckoutTop")
If CmdMan.Enabled = True Then
MsgBox "will be checked out"
CmdMan.Execute 'CmdMan.Execute2 (True)
End If
End SubFor I logic
Public Sub Main()
a = ThisApplication
MsgBox ("will be checked out")
End If
End SubRegards,
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
