Changing iProperties with iLogic
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm making a code that allows me to fill existing and create new custom iProperties in batches of partfiles, this infomation comes from an Excel file. Unfortunatly the code does everything correctly except changing the actual properties
The code gives the correct iProperty types, names and values (line 52);
But the value of the properties do not change when it runs line 54, no errors occur either.
My code (not all of it is important, i think the problem lies in line 54);
Imports System.Windows.Forms
Sub main
Dim rDocs As Documents = ThisApplication.Documents
Dim oFD As Inventor.FileDialog = Nothing
InventorVb.Application.CreateFileDialog(oFD)
oFD.InitialDirectory = oOrigRefName
oFD.Filter = "Excel file (*.xlsx)|*.xlsx|"
oFD.CancelError = True
On Error Resume Next
oFD.ShowOpen()
If Err.Number <> 0 Then
Return
ElseIf oFD.FileName <> "" Then
selectedfile = oFD.FileName
End If
Dim oExcel As String = selectedfile
Dim i As Integer = 3
Dim PartFileLoc As String = GoExcel.CellValue(oExcel, "Blad1", "A" & i)
If PartFileLoc = "" Then
MsgBox("Geen PartFileLoc gevonden in cell: A" & i)
Exit Sub
End If
Do While PartFileLoc <> ""
Dim oPartDoc As PartDocument = rDocs.Open(PartFileLoc, True)
oPartDoc.Activate
Dim n As Integer
Dim nRow As Integer = 2
For n = 1 To 26
oLetter = Mid("ABCDEFGHIJKLMNOPQRSTUVWXYZ", n, 1)
oCellAddress = oLetter & nRow
oCellValue = GoExcel.CellValue(oCellAddress)
GoExcel.TitleRow = nRow
oColumnName = GoExcel.CellValue(oLetter & nRow)
If oColumnName <> ""
Dim oProperty As String = oColumnName
Dim oPropertyType As String = GoExcel.CellValue(oLetter & 1)
Dim oSetValue As String = GoExcel.CellValue(oExcel, "Blad1", oLetter & i)
MsgBox(oPartDoc.DisplayName)
MsgBox(oPropertyType & " & " & oProperty & " = " & oSetValue)
iProperties.Value(oPropertyType, oProperty) = oSetValue
End If
Next
i = i + 1
PartFileLoc = GoExcel.CellValue("A" & i)
oPartDoc.Save()
'oPartDoc.Close
Loop
End Sub
What am i doing wrong?
have a good weekend in advance
