Change view like command LookAt
Hello guys!...
I would like to know how i can make the view be at on the Sketch.
It should work like "LookAt" command.
Thanks for your attention.
Luizoo from Brazil
Try the macro below that programmatically selects the object to be "viewed"
(in this case, the Y-Z workplane) and executes the 'Look At' command.
Sanjay-
Sub LookAt()
Dim oDoc As PartDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oDef As PartComponentDefinition
Set oDef = oDoc.ComponentDefinition
Dim oWorkplane As WorkPlane
Set oWorkplane = oDef.WorkPlanes.Item(1)
oDoc.SelectSet.Clear
oDoc.SelectSet.Select oWorkplane
Dim oCtrlDef As ControlDefinition
Set oCtrlDef =
ThisApplication.CommandManager.ControlDefinitions("AppLookAtCmd")
oCtrlDef.Execute
End Sub
Thank you Sanjay for your suggest.
In this way i know, but i would like to make that without use an inventor command.
Thank for your attention.
Luizoo from Brazil
That is possible to do by manipulating the view's camera. You'll need to set
the appropriate eye, target and up vector.
Sanjay-
Dim oView As View
Set oView = ThisApplication.ActiveView
Dim oCamera As Camera
Set oCamera = oView.Camera
oCamera.Eye = ...
oCamera.Target = ...
oCamera.UpVector = ...
oCamera.Apply
Ok, thanks a lot.
I understood that.
Thanks for your attention again.
Luizoo from Brazil
FRFR1426
Here is the C# code to do that for a sketch based on a work plane:
  var workPlaneObject = (WorkPlane)sketch.PlanarEntity;
  Plane plane = workPlaneObject.Plane;
  camera.Target = plane.RootPoint;
  Point eye = plane.RootPoint.Copy();
  eye.TranslateBy(plane.Normal.AsVector());
  camera.Eye = eye;
  camera.UpVector = plane.Normal.CrossProduct(sketch.AxisEntityGeometry.Direction);
  camera.Apply();
Maxence DELANNOY
Manager
Add-ins development for Autodesk software products
http://wiip.fr
