Change the background image file path
danny.lewisA9QBW
danny.lewisA9QBW
I've seen lots of forum postings about changing the background colour, but I can't find anything about changing the background to the 'background image' and then providing what the path should be.
...shouldn't be too hard right?
Curtis_Waguespack
Hi @danny.lewisA9QBW
See these quick iLogic examples
I hope this helps.
Curtis
oInput = InputRadioBox("Select one", "Use Image", "Don't Use Image", True, "iLogic")
oSchemes = ThisApplication.ColorSchemes
If oInput = True Then
	oSchemes.BackgroundType = BackgroundTypeEnum.kImageBackgroundType
	ThisApplication.ActiveColorScheme.ImageFullFileName = "C:\Temp\BG1.jpg"
Else
	oSchemes.BackgroundType = BackgroundTypeEnum.kOneColorBackgroundType
End If
oInput = InputRadioBox("Select one", "Use Image1", "Use Image2", True, "iLogic")
	oPath = "C:\Temp\BG1.jpg"
Else
	oPath = "C:\Temp\BG2.jpg"
End If
ThisApplication.ActiveColorScheme.ImageFullFileName = oPath
jjstr8
Are you looking for Application.ActiveColorScheme.ImageFullFileName?
danny.lewisA9QBW
I was looking for the where I would even put that path in Yes.  The help files were pretty thin on details when you look up 'Background Image', it just gives the enum value stuff; nothing else.
jjstr8
I agree. Since BackgroundType applies to all color schemes, you would think that the help file would spell that out better in ColorScheme Object.
