Change Section View Direction iLogic
Hello there,
I was wondering if it is possible to change the direction of a Section View with the use of iLogic.
So far I have not been able to determine the direction property and found no threads which adress this problem.
Curtis_Waguespack
Hi Jake_M.,
There isn't an ilogic method to do this, but you can use an API call in an iLogic rule for this.
Here's an example (note that it expects the 2nd view on the sheet to be a section view).
Also just as a tip, you can search and ask programming questions of this type on the Inventor Customization forum:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I hope this helps.
Curtis
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveDocument
Dim oView As SectionDrawingView
'expects the 2nd view on the sheet to be a section view
oView = oDoc.ActiveSheet.DrawingViews.Item(2)
'flip the section view direction
oView.ReverseDirection
That's exactly what I needed.
Thanks!
