Change Part Colour Using "RGB" Values
isocam
isocam
Can anybody help?
I am trying to set the colour of a part, via a VBA macro, using RGB Values.
Can someone try the following VBA macro on a Inventor part (ipt) document and let me know if you are getting the same error as me?
Public Function SetPartColour()
Dim oDoc As PartDocument
Set oDoc = ThisApplication.ActiveDocument
Dim color As ColorAssetValue
Set color = oDoc.ActiveAppearance.Item("generic_diffuse")
color.Value = ThisApplication.TransientObjects.CreateColor(Red, Green, Blue)
End Function
I get an error on the line highlighted in RED
Does anybody know how I can fix the error?
Many thanks in advance!!!!
Darren
mcgyvr
What version of Inventor are you using?
isocam
I am currently using 2021 (And testing 2022).
Are there different macros to change the colour depending on what version of inventor you are using?
Kind Regards
Darren
FINET_Laurent
Here is how I do it :
Dim oAppearence As Asset
oAppearence = oDoc.Assets.Add(kAssetTypeAppearance, "Generic", "Appearances")
Dim oColor As ColorAssetValue
oColor = oAppearence.Item("generic_diffuse")
oColor.Value = ThisApplication.TransientObjects.CreateColor(0,145,255)
oExtrude1.Appearance = oAppearence
 oExstrude1 is set before hand.
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
Curtis_Waguespack
Hi @isocam
In case it's of interest, attached is a 2019 file that creates a new appearance in the part and allows you to use sliders in a form to change the color dynamically.
I hope this helps.
Curtis
