Change parameters in a different part from the iLogic code.
Jam_Jumpin
Jam_Jumpin
Here's what I am trying to do.
I will open the part and run a rule
Save a copy of the part to a temp location
Alter some parameters on this part
Save it to it's final location
Close the temporary part window.
I can do all these things, but the issue is that I do not know how to change the parameter in the temp part, it is changing the parameters in the part that the rule is running in.
w is the parameter I am trying to change.
TempFile="C:\Users\***\Target\temp_part.ipt"
TargetFile="C:\Users\***\Target\New file.ipt"
ThisDoc.Document.SaveAs(TempFile , True)
Temp2=ThisApplication.Documents.Open(TempFile)
w = InputBox("Width", "Size", "10")
InventorVb.DocumentUpdate()
Temp2.SaveAs(TargetFile, True)
Temp2.Close
All the forum posts I could find related to the part being in an assembly which is not how I am doing this.
Replies (8)
JamieVJohnson2
parameters and properties allow you to specify the file as well as the parameter/property name in an overloaded option.  This means you can force the active (or choice) file into the parameter call instead of the 'current' file.
jvj
chandra.shekar.g
Autodesk Support
Autodesk Support
@Jam_Jumpin,
Hoping that below iLogic code may helpful.
ThisDoc.Document.SaveAs(TempFile, True)
Dim Temp2 As PartDocument
Temp2 = ThisApplication.Documents.Open(TempFile)
Dim oDef As PartComponentDefinition
oDef = Temp2.ComponentDefinition
oDef.Parameters.Item("w") = InputBox("Width", "Size", "10")
Temp2.Close
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Jam_Jumpin
Error on Line 12 : Property 'Item' is 'ReadOnly'.
Line 12 is
chandra.shekar.g
Autodesk Support
Autodesk Support
@Jam_Jumpin,
Can you please provide non confidential sample part to test? please mention the Inventor version as well.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Jam_Jumpin
Simply using a square block to test. Attached.
Inventor 2018
chandra.shekar.g
Autodesk Support
Autodesk Support
@Jam_Jumpin ,
Try below iLogic code.
Temp2 = ThisApplication.Documents.Open(TempFile, True)
oDef.Parameters.Item("w").Expression = InputBox("Width", "Size", "10")
Call Temp2.Update
Temp2.Close
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Jam_Jumpin
Thanks, that works now but I don't understand why it works. Please can you have a look? I have commented out what I think is happening in each stage.
I also don't really understand what the command DIM does.
It's great getting help on the internet but if I don't understand it I will never learn to do it myself.
Thank you!
'location of temporary folder
TempFile="***\temp_part.ipt"
'Location of target folder
TargetFile="***\New file.ipt"
'Save a temporary file
'Declares Temp2 as a PartDocument variable?
'Switches ilogic focus to the open temp file?
'Definies the temp part's parameters as a variable?
'Switches iLogic focus to the temp parameters instead of where rule is running?
'Sets the temp part parameter from input box
'forces a rebuild?
Call Temp2.Update
'Saves temp file as new file in target location
'Close Temp file
Temp2.Close
chandra.shekar.g
Autodesk Support
Autodesk Support
@Jam_Jumpin ,
ThisDoc means always focus would be in a document where iLogic rule is running. To shift the focus to current document, Temp2 variable is defined. After that, parameters are accessed from componentdefinition.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
