Change my Operating System to Windows 10
Hi out there.
I have Inventor 2013 and 2016 in two PC, but the OS is W7 want to see if somebody knows if there are not more trouble with W10 OS, to update to windows 10.
Alex Gutz
mercerc
You may hear all type of negative as well as positive on Windows 10. What I would advise from an Inventor/Autodesk end is before migrating a system from one OS (Windows 7 in your case) to Windows 10 is to do a clean uninstall of your Inventor product. The reason for that is each OS has different methods of dealing with our files. Installing on new OS will ensure that you set up a more stable install of Inventor.
I would only install Inventor 2016 as your version of Inventor 2013 was never intended for Windows 10. Once install and be running I would also apply all updates and service packs for your version of Inventor.
Clean uninstall of Inventor 2016 link:
Updates and service packs Inventor 2016 Link:
Charlie M
Inventor Product Support Specialist
