Announcements
Change iPart member
Hubert_Los
Change iPart member
Hubert_Los
I am trying to change an iPart member in VBA, but I don't know how to use "ChangeRow" function.
Sub iPartsChangeRow()
    Dim oDoc As AssemblyDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oAssemblyComponent As AssemblyComponentDefinition
    Set oAssemblyComponent = oDoc.ComponentDefinition
    Dim oComponentOccurrenceToChange As ComponentOccurrence
    Set oComponentOccurrenceToChange = ThisApplication.CommandManager.Pick(kAssemblyOccurrenceFilter, "Wybierz element do zmiany")
    Dim oIPartMember As iPartMember
    Set oIPartMember = oComponentOccurrenceToChange.Definition.iPartMember
    Dim oFactory As iPartFactory
    Set oFactory = oIPartMember.ParentFactory
    Dim oPartIdentifier As String
    oPartIdentifier = oFactory.TableRows.Item(5).PartIdentifier
    oIPartMember.ChangeRow (oPartIdentifier)
End Sub
A.Acheson
There is a dedicated method from component occurrence. See API help page and article showing the method.
Syntax
ComponentOccurrence.ChangeRowOfiPartMemberNewRow As Variant, [CustomInput] As Variant )
Regards
Alan
