CHANGE HEIGHT IN TEXT BOX (SKETCH 2D) ILOGIC
roberto_infanti
Message 1 of 12
roberto_infanti
I'VE CREATED A MACRO THAT INSERTS TEXT AND CREATES THE INSTRUCTION ON A SELECTED FACE. HOW DO I CHANGE THE TEXT HEIGHT FROM ILOGIC RULE?
FOR THE BEST ONES: HOW DO I CHOOSE WITH ONE CLICK THE INSERTION POINT OF THE TEXT BOX (THE GEOMETRIC CENTER OF THE FACE COULD ALSO BE FINE)
' Dichiarazione delle variabili
Dim oPart As PartDocument
Dim oFace As Face
Dim oSketch As PlanarSketch
Dim oText As TextBox
Dim oExtrudeDef As ExtrudeDefinition
' Ottieni il documento corrente
oPart = ThisApplication.ActiveDocument
' Seleziona la faccia
oFace = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Seleziona una faccia")
' Crea uno schizzo sulla faccia selezionata
oSketch = oPart.ComponentDefinition.Sketches.Add(oFace)
' Aggiungi il testo allo schizzo
oText = oSketch.TextBoxes.AddFitted(ThisApplication.TransientGeometry.CreatePoint2d(0, 0), "PROVA")
' Crea un profilo dallo schizzo
Dim oProfile As Profile
oProfile = oSketch.Profiles.AddForSolid()
' Crea la definizione dell'estrusione
oExtrudeDef = oPart.ComponentDefinition.Features.ExtrudeFeatures.CreateExtrudeDefinition(oProfile, PartFeatureOperationEnum.kCutOperation)
' Imposta la distanza di estrusione
oDistance = 0.5
' Imposta l'estrusione per essere simmetrica
oExtrudeDef.SetDistanceExtent(oDistance, PartFeatureExtentDirectionEnum.kSymmetricExtentDirection)
' Crea l'estrusione
Dim oExtrude As ExtrudeFeature
oExtrude = oPart.ComponentDefinition.Features.ExtrudeFeatures.Add(oExtrudeDef)
Replies (11)
Message 2 of 12
roberto_infanti
SOLUTION WITH NEW STYLE:
Dim oFace As Face
oText = oSketch.TextBoxes.AddFitted(ThisApplication.TransientGeometry.CreatePoint2d(0, 0), NOME_FILE,"NOTA_STAMPI_3D_H30MM")
oDistance = 0.5
' Crea l'estrusione
oExtrude = oPart.ComponentDefinition.Features.ExtrudeFeatures.Add(oExtrudeDef) WITH
Message 3 of 12
Michael.Navara
Here is modified your first example with automatic face center detection and input for text height
Sub Main()
    Dim oFace As Face
    Dim oText As Inventor.TextBox
    Dim position As Point2d = GetPosition(oSketch)
    Dim height As Double = Double.Parse(InputBox("Input height [mm]", "Input text height", "30")) / 10
    Dim formattedText As String = GetFormattedText("PROVA", height)
    oText = oSketch.TextBoxes.AddFitted(position, formattedText)
    oText.VerticalJustification = VerticalTextAlignmentEnum.kAlignTextMiddle
    oText.HorizontalJustification = HorizontalTextAlignmentEnum.kAlignTextCenter
    Dim oDistance = 0.5
    ' Crea l'estrusione
End Sub
Private Function GetPosition(sketch As PlanarSketch) As Point2d
    'Dim position As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(0, 0)
    Dim face As Face = CType(sketch.PlanarEntity, Face)
    If face Is Nothing Then
        Return ThisApplication.TransientGeometry.CreatePoint2d(0, 0)
    Dim paramRangeRect As Box2d = face.Evaluator.ParamRangeRect
    Dim centerParamX = (paramRangeRect.MaxPoint.X + paramRangeRect.MinPoint.X) / 2
    Dim centerParamY = (paramRangeRect.MaxPoint.Y + paramRangeRect.MinPoint.Y) / 2
    Dim points As Double() = {}
    face.Evaluator.GetPointAtParam({centerParamX, centerParamY}, points)
    Dim positionInModelSpace As Point =
            ThisApplication.TransientGeometry.CreatePoint(points(0), points(1), points(2))
    Dim positionInSketchSpace As Point2d = sketch.ModelToSketchSpace(positionInModelSpace)
    Return positionInSketchSpace
End Function
Private Function GetFormattedText(content As String, height As Double) As String
    Return String.Format("<StyleOverride FontSize='{1}'>{0}</StyleOverride>", content, height)
End Function
Message 4 of 12
roberto_infanti
Good morning! Perfect!! Congratulations! Can I ask you one more thing? Let's see if I can explain. If I enter the text manually, I'm going to insert it as a "user parameter", so the file updates every time it changes. On the other hand, when I insert it through the ilogic rule, it is not a parameter but it is a common text. Is there a way to put it on the ilogic rule?
Basically, I have a .ipt file that has the writing on many faces. I use the same file as a master to create others. The inscription has the data from ipropeties. Thanks
Message 5 of 12
Michael.Navara
Everything is about FormattedText. The easiest way is to create text manually and look in to the FormattedText property of TextBox. Then you can update the code.
Message 6 of 12
roberto_infanti
Unfortunately I can't find anything....help me....Thanks
Message 7 of 12
Michael.Navara
1) Create text box in the sketch
2) Set format and content as you want
3) Look in to the API. For example using my tool VBA Object Browser for Inventor or print the FormattedText to iLogic log console.
4) Look at the value of this property
5) You get string value similar to this
"<StyleOverride FontSize='1,'><Parameter Resolved='True' ComponentIdentifier='Part1' Name='test' Precision='3'>1.000</Parameter></StyleOverride>"
Update the code according to this.
More info about FormattedText tags is here.
Message 8 of 12
roberto_infanti
YOU ARE MAKING ME DISCOVER A NEW WORLD. I'LL GIVE IT A TRY! THANK YOU
Message 9 of 12
roberto_infanti
Message 10 of 12
roberto_infanti
Sub Main()
    Dim oApp As Inventor.Application
    oApp = ThisApplication
    oPart = oApp.ActiveDocument ' Corrected line
    ' Clear the current selection set
    oApp.ActiveDocument.SelectSet.Clear()
    ' Allow the user to select a face
    Dim oFace As Face
    oFace = oApp.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Seleziona una faccia")
    ' Add the selected face to the selection set
    oApp.ActiveDocument.SelectSet.Select(oFace)
    ' Now you can create a sketch on the selected face
    oSketch = oPart.ComponentDefinition.Sketches.Add(oFace) ' Corrected line
    Dim oTG As TransientGeometry
    oTG = oApp.TransientGeometry
    'Dim height As Double = Double.Parse(InputBox("Input height [mm]", "Input text height", "30")) / 10
    oText = oSketch.TextBoxes.AddFitted(position, "<Parameter ComponentIdentifier='" & oPart.FullFileName & "' Name='NOME_FILE' Precision='2' ></Parameter>","NOTA 30 MM") ' Corrected line
    oPart.Update2(True) ' Corrected line
    Dim oExtrudeDef As ExtrudeDefinition ' Corrected line
    Dim oDistance As Double = 0.5 ' Corrected line
    ' Crea l'estrusione
End Sub
End Function
Message 11 of 12
projetos33
I'm trying to create a sketch on the unfolded part, but I'm having trouble.
I'm doing it in iLogic, and when I run the rule, it creates a sketch on the face of the unfolded view, and creates a text box with the file name.
I need this name to be in the size 6.00mm and Font: "Txt"
This rule works on metal parts with unfolding.
Sub Main()
    ' Obter o documento ativo
    Dim oPartDoc As PartDocument
    oPartDoc = ThisApplication.ActiveDocument
    ' Verificar se o documento é uma chapa metálica
    If oPartDoc.ComponentDefinition.Type <> 150995200 Then
        MessageBox.Show("O arquivo não é uma peça de chapa metálica.", "iLogic")
        Exit Sub
    ' Obter a definição da peça de chapa metálica
    Dim oCompDef As SheetMetalComponentDefinition
    oCompDef = oPartDoc.ComponentDefinition
    ' Verificar e ativar a vista planificada
    If Not TypeOf ThisApplication.ActiveEditObject Is FlatPattern Then
        Try
            If oCompDef.HasFlatPattern = False Then
                oCompDef.Unfold
            Else
                oCompDef.FlatPattern.Edit
        Catch
            MessageBox.Show("Erro ao ativar a vista planificada.", "iLogic")
            Exit Sub
        End Try
    ' Obter a vista planificada
    Dim oFlatPattern As FlatPattern
    oFlatPattern = ThisApplication.ActiveEditObject
    ' Obter a face do padrão planificado
    Dim oFace As Face
    oFace = oFlatPattern.TopFace
    ' Nome do esboço e do corte
    Dim sSketchName As String
    Dim sTextFeatureName As String
    sSketchName = "Text Marking Sketch"
    sTextFeatureName = "Text Marking"
    ' Remover esboço existente, se houver
    For Each oSketch In oFlatPattern.Sketches
        If oSketch.Name = sSketchName Then
            oSketch.Delete
    Next
    ' Criar um novo esboço na face planificada
    oSketch = oFlatPattern.Sketches.Add(oFace, False)
    ' Obter o nome do arquivo (sem extensão)
    Dim sFileName As String
    sFileName = System.IO.Path.GetFileNameWithoutExtension(oPartDoc.FullFileName)
    ' Criar um ponto de origem para o texto
    Dim oTransGeom As TransientGeometry
    oTransGeom = ThisApplication.TransientGeometry
    Dim oTextPosition As Point2d
    oTextPosition = oTransGeom.CreatePoint2d(0, 0) ' Posição inicial (pode ser ajustada)
    ' Adicionar um texto ao esboço
Dim oTextBox As Inventor.TextBox
oTextBox = oSketch.TextBoxes.AddFitted(oTextPosition, sFileName)
    ' Mensagem de sucesso
    MsgBox ("Marcação com o nome da peça foi adicionada!", vbInformation, "Concluído")
End Sub
Message 12 of 12
Curtis_Waguespack
see answer in duplicate post here:
https://forums.autodesk.com/t5/inventor-programming-ilogic/ilogic-text-box-size-and-font-flat-patter...
