Change Font Size, Font Char by Excel Sheet
Sorry for my bad English.
I have a Problem with Changing a Font Size and Font Char by Using an Excel Sheet. I got a master. Ipt what ist connected to an excel sheet. In the Font ipt I added some lines in I logic like in this post:
https://forums.autodesk.com/t5/inventor-forum/having-text-size-based-on-another-parameter/m-p/825234...
Message 3 and 4 of 18
Then I connected the Master ipt with the Font ipt and used the parameters of the excel sheet added in the master ipt.
If I change now the Font size and Font Char in the excel sheet the update symbol in the Font ipt shows up, but if I press it the Font won't update.
Do you have an idea how I can fix this. Maybe by adding some lines in I logic.
WCrihfield
Can you provide some sample files (nothing proprietary or confidential) that we can test the requested functionality on?  And/or can you explain in a lot more detail exactly what you have in these two model files, what all you have in the Excel file, and in what ways you need them all to communicate with each other?  Exactly how did you "connect" the Master.ipt with the Font.ipt parts?  When you say you want to change the "Font Char", do you mean you want to change the contents of the text, change a single character in the text, or change to a totally different Font?
Wesley Crihfield
(Not an Autodesk Employee)
Thank you for your quick answer.
I can't send you the file because it's from my Company.
I don't really know what i have changed, but now it seems to work.
Have some nice Christmas Days and stay healthy !
