Centralize Dimension Text
cad
cad
Hi
I am at the first stage of iLogic.
Just Making some simple Conditional or Mathematical codes.
I got a code below to Centralize the Dimension text.
That works perfectly on the Active sheet.
Can I use something similar that works for All the sheets of Current Document. ?
    ' Set a reference to the active drawing document
    Dim oDoc As DrawingDocument
     oDoc = ThisDoc.Document
    ' Set a reference to the active sheet
    Dim oSheet As Sheet
     oSheet = oDoc.ActiveSheet
    Dim oDrawingDim As DrawingDimension
    ' Iterate over all dimensions in the drawing and
    ' center them if they are linear or angular.
    For Each oDrawingDim In oSheet.DrawingDimensions
        If TypeOf oDrawingDim Is LinearGeneralDimension Or _
           TypeOf oDrawingDim Is AngularGeneralDimension Then
             oDrawingDim.CenterText
    Next
Thanks.
Yes you can use it in all sheet with following code
Dim odoc As Document
odoc = ThisApplication.ActiveDocument ' Set a reference to the active sheet Dim oSheet As Sheet For Each oSheet in oDoc.Sheets Dim oDrawingDim As DrawingDimension ' Iterate over all dimensions in the drawing and ' center them if they are linear or angular. For Each oDrawingDim In oSheet.DrawingDimensions If TypeOf oDrawingDim Is LinearGeneralDimension Or _ TypeOf oDrawingDim Is AngularGeneralDimension Then oDrawingDim.CenterText End If Next
Next
cad
Perfect !!!
Many thanks.
