Center of Gravity
Center of Gravity
I have a problem. Im student form Poland, and im designing gimbal for GoPro. I modeled GoPro as a single solid, and choosen material which gives similar to true weight. But here is a problem with COG(Center of Gravity), because it is wrong, it is somewhere in the center, but in fact it is not. I found at official GoPro site coordinates of COG. I would like to update COG to my own coordinates, is it possible?
Example:
COG in iproperties is: x =10, y = 5, z = 50 and i want to change it to x = 1, y = 10, z = 60, and don't want to change anything else.
VdVeek
To me it seems imposible to change/overrule the COG, why not create a hidden cut-out in your model and manualy change the material density afterwards?
Autodesk Inventor 2015 Certified Professional & Autodesk Inventor 2012 Certified Professional.
ekinsb
Someone else has requested the same capability using the IdeaStation.  Someone else responded with a workaround that I believe should work in your case.
https://forums.autodesk.com/t5/inventor-ideastation/ability-to-override-center-of-gravity/idi-p/4742...
Brian Ekins
Mod the Machine blog
