Cannot Create ActiveX Component Excel Macro
I have a code that runs a macro inside an excel sheet which oddly sometimes works and sometimes doesnt. Same code, no changes at all.
Quite often I get the error saying "Cannot Create ActiveX Component"
When I try and run the rule multiple times back to back it cant run it after the first time.
Im thinking its because the file is open in a hidden state although I told ilogic to save & close the excel file.
Here's the code below:
Dim xlsxPath As String
			xlsxPath = "C:\Users\tm04.smeric\Desktop\Meric\WELD DETAIL LIST.xlsm"
			GoExcel.Open(xlsxPath, "Sheet1")
			'''MACRO'''
			Dim XL As Object
'				XL = CreateObject("Excel.Application")
				XL = GetObject(, "Excel.Application")
				XL.Run("Module1.clearMacro")
			GoExcel.DisplayAlerts = False
' GoExcel.Save()
' GoExcel.Close()
 Thanks in advance :slightly_smiling_face:
I also get the error if I close excel from the task manager as I assume it fails to activate macros unless you open the excel on startup and save it after you open VBA
