Can't find path of referenced file
Electrik
Electrik
I can't find the right text to get the File path of a referenced document within an IAM.
I have the code below. This gets me the full path (including filename) for each child of the parent IAM (from which the rule was run). I'm just using a message box as a simple diagnostic tool, to show what I'm getting.
Instead of "FullFileName", how do I get the Path WITHOUT the filename and extension?
Yes, ThisDoc.Path works when I'm within the "root level", but refDoc.Path is not working in this case.
I feel I'm missing something obvious.
Dim oAsmDoc As AssemblyDocument = ThisApplication.ActiveDocument
Dim oDoc As Document = ThisDoc.Document
For Each refDoc As Document In oDoc.AllReferencedDocuments
    MessageBox.Show(refDoc.FullFileName, "file path")
Inventor Professional 2021
Vault Professional 2021
JelteDeJong
you can try it like this:
	Dim path = System.IO.Path.GetDirectoryName(refDoc.FullFileName)
	MessageBox.Show(path, "file path")
Next
Jelte de Jong
Blog: hjalte.nl - github.com
Electrik
Yes! Thank you!
