can not able to Saveas using VBA
Saveas Issue.PNGHi to All.
Can some boy explain me why the error is coming and the solution too.
imajar
Documentation says:
Syntax
AssemblyDocument.SaveAsFileName As String, SaveCopyAs As Boolean )
you need to reference the document you are trying to save ie:  oDoc.SaveAs( FileName, True)
Also, there is another forum here called "Inventor Customization" for programming questions where you will probably get quicker and better answers.  Good Luck.
Aaron Jarrett, PE
Inventor 2019 | i7-6700K 64GB NVidia M4000
LinkedIn
Life is Good.
JaneFan
Besides referencing to document to call the method as @imajar mentioned, there is some common syntax tricks in VBA that it supports calling a method in either of the ways, take Document.SaveAs as example:
1.With parenthesis:  Call Document.SaveAs(Param1, Param2)
2. With paraenthesis: Document.SaveAs Param1, Param2
Code example:
Dim oDoc As AssemblyDocument
Set oDoc = ThisApplication.ActiveDocument
oDoc.SaveAs "c:\temp\aa.iam", False
Jane Fan
Inventor QA Engineer
_dscholtes_
Given the fact I see various 'End With' statements and a '.Close' statement, leads me to believe the 'SaveAs' command in the red line of code should also precede with a '.
Noticing the fact there's a '.SaveAs' statement commented out above the red line of code and assuming that is done because it didn't work, lends me to believe something's wrong with your 'With' statements.
