Can I use iLogic to create a new drawing using pages from multiple pre-existing drawings.
mmurray1629
mmurray1629
I currently have a parent assembly made of 10 children sub-assemblies, each of which has 2-5 possible model state configurations.  I have drawings already made for all of the model states, but I’m looking for a more efficient way to generate the 10 page drawing.  I was hoping to create an iLogic program that checks to see which model states are active and then generates a dwg by copying the corresponding page to that model state into a new file.  Does this sound possible?  I’m not sure where to start.
WCrihfield
Hi @mmurray1629.  What you described sounds pretty complicated, so my 'short' answer would be maybe.  There is an Inventor API method for copying a 'Sheet' from one drawing to another drawing (Sheet.CopyTo).  However, a whole sheet does not have its own 'ModelState', so I suspect you mean that each sheet in your drawing is for one ModelState version of a single model file, and if so, you would have to check a property of one of the DrawingView objects on each sheet (DrawingView.ActiveModelState).  That is a ReadOnly property with a String type value, so if you need to 'set' its value, you have to use the DrawingView.SetActiveModelState method.  Knowing about these should help with some of the 'how to get started' stuff.  But since I do not do much copying sheets from one large assembly drawing to another by code where I work, I can not be 100% sure if everything else you are wanting to accomplish will work out smoothly.
Wesley Crihfield
(Not an Autodesk Employee)
mmurray1629
I was able to achieve this with two separate codes - one on my model which opens drawings based on the name of the model state (model state name must match drawing name), then once all the sheets are open, I have a copy sheets to drawing code.
For those interested in functionality similar to this, here is my "Open Drawings" code:
Imports System.IO
Imports System.Windows.Forms
Sub Main()
Try
' Define the base folder path
Dim baseFolderPath As String = "C:\VaultWorkspace\InventorWorkspace"
' Check if the active document is an assembly
If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
MessageBox.Show("The active document is not an assembly. Please open an assembly document and try again.", "Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
Exit Sub
End If
' Get the active assembly document
Dim oAsmDoc As AssemblyDocument = ThisApplication.ActiveDocument
' Initialize lists to hold the file paths and display names of the drawings to be checked
Dim drawingFiles As New List(Of String)
Dim drawingDisplayNames As New List(Of String)
' HashSet to track processed sub-assemblies and model states
Dim processedSubAssemblies As New HashSet(Of String)
' Get the assembly component definition
Dim oCompDef As AssemblyComponentDefinition = oAsmDoc.ComponentDefinition
' Add the top-level assembly itself to the search
Dim topLevelAssemblyName As String = System.IO.Path.GetFileNameWithoutExtension(oAsmDoc.FullFileName)
Dim topLevelDrawingName As String = topLevelAssemblyName & ".idw"
drawingFiles.Add(topLevelDrawingName)
drawingDisplayNames.Add("Top-level Assembly: " & topLevelAssemblyName)
' Iterate through each component in the assembly
For Each oOccurrence As ComponentOccurrence In oCompDef.Occurrences
Try
' Check if the component is a subassembly
If oOccurrence.DefinitionDocumentType = kAssemblyDocumentObject Then
' Get the file name without extension
Dim fileNameWithoutExtension As String = System.IO.Path.GetFileNameWithoutExtension(oOccurrence.Definition.Document.FullFileName)
' Construct the model state name identifier
Dim modelStateIdentifier As String = oOccurrence.Name
' Retrieve the active model state name
Dim activeModelStateName As String = Component.ActiveModelState(modelStateIdentifier)
' Create a unique key combining the file name and model state
Dim uniqueKey As String = fileNameWithoutExtension & " | Model State: " & activeModelStateName
' Check if the sub-assembly with the model state has already been processed
If Not processedSubAssemblies.Contains(uniqueKey) Then
' Add the unique key to the HashSet
processedSubAssemblies.Add(uniqueKey)
' Get the full file name
Dim fullFileName As String = System.IO.Path.GetFileName(oOccurrence.Definition.Document.FullFileName)
' Create a display name for the checkbox
Dim displayName As String = "Sub-assembly: " & fullFileName & vbCrLf & "Active Model State: " & activeModelStateName
drawingDisplayNames.Add(displayName)
' Construct the expected drawing file name
Dim drawingFileName As String = fileNameWithoutExtension & " (" & activeModelStateName & ").idw"
drawingFiles.Add(drawingFileName)
End If
End If
Catch ex As Exception
MessageBox.Show("Error processing component: " & oOccurrence.Name & " - " & ex.Message, "Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
End Try
Next
' Show the custom form with dynamically created checkboxes
Dim selectedDrawings As List(Of String) = ShowSelectionFormWithCheckBoxes(drawingDisplayNames, drawingFiles)
If selectedDrawings.Count = 0 Then
MessageBox.Show("No drawings selected. Exiting.", "Selection Required", MessageBoxButtons.OK, MessageBoxIcon.Information)
Exit Sub
End If
' Initialize a string to hold the results of the drawing file checks
Dim drawingResults As String = ""
' Initialize lists to hold the found and not found drawing file paths
Dim foundDrawingFiles As New List(Of String)
Dim notFoundDrawingFiles As New List(Of String)
' Check if each selected drawing file exists in the entire directory structure and add the result to the display text
For Each drawingFile In selectedDrawings
Try
' First attempt: Search for drawing file with model state
Dim foundFiles As String() = Directory.GetFiles(baseFolderPath, drawingFile, SearchOption.AllDirectories)
' Check if found
If foundFiles.Length > 0 Then
foundDrawingFiles.Add(foundFiles(0)) ' Add to found files list
drawingResults &= "Drawing file found: " & drawingFile & vbCrLf
Else
' Prepare for secondary search
drawingResults &= "Drawing file not found: " & drawingFile & vbCrLf
notFoundDrawingFiles.Add(drawingFile) ' Add to not found files list
End If
' Add a separator line
drawingResults &= "------------------------" & vbCrLf
MessageBox.Show("Error searching for drawing file: " & ex.Message, "Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
End Try
Next
' Display the first message box with updated instructions
Dim openDrawingsResult As DialogResult = DisplayMessageInChunks(drawingResults, "Drawing File Check Results", 50, False, "Would you like to open the drawings that were found?")
' Always continue to the secondary search regardless of the user's response
Dim secondarySearchResults As String = ""
For Each drawingFile In notFoundDrawingFiles
Try
' Remove only the last set of parentheses and its content
Dim baseFileName As String = RemoveLastParentheses(drawingFile) & ".idw" ' Append the .idw extension
Dim foundFiles As String() = Directory.GetFiles(baseFolderPath, baseFileName, SearchOption.AllDirectories)
secondarySearchResults &= "Drawing file found: " & baseFileName & vbCrLf
Else
secondarySearchResults &= "Drawing file still not found: " & baseFileName & vbCrLf
End If
secondarySearchResults &= "------------------------" & vbCrLf
MessageBox.Show("Error in secondary search: " & ex.Message, "Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
End Try
Next
' Display the third message box with updated instructions
Dim secondarySearchResultDialog As DialogResult = DisplayMessageInChunks(secondarySearchResults, "Secondary Search Results", 50, False, "Would you like to continue opening the drawings that were found?")
If secondarySearchResultDialog = DialogResult.Yes Then
' Open any newly found drawing files from the secondary search
For Each drawingFilePath In foundDrawingFiles
ThisApplication.Documents.Open(drawingFilePath, True)
Next
End If
MessageBox.Show("An unexpected error occurred: " & ex.Message, "Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
End Try
End Sub
' Function to display a custom form with dynamically created checkboxes
Function ShowSelectionFormWithCheckBoxes(drawingNames As List(Of String), drawingFiles As List(Of String)) As List(Of String)
Dim form As New Form()
form.Text = "Select Drawings to Open"
form.Width = 500
form.Height = 400
form.StartPosition = FormStartPosition.CenterScreen
Dim panel As New Panel()
panel.Dock = DockStyle.Fill
panel.AutoScroll = True
Dim checkBoxes As New List(Of CheckBox)()
' Add each checkbox dynamically
For i As Integer = 0 To drawingNames.Count - 1
Dim checkBox As New CheckBox()
checkBox.Text = drawingNames(i)
checkBox.AutoSize = True
checkBox.Top = i * 30 + 60 ' Adjust position for space after instruction
checkBox.Left = 10 ' Set left margin
panel.Controls.Add(checkBox)
checkBoxes.Add(checkBox)
Next
Dim instructionLabel As New Label()
instructionLabel.Text = "Please select which drawings you would like to open."
instructionLabel.Dock = DockStyle.Top
instructionLabel.Height = 40
form.Controls.Add(instructionLabel)
Dim okButton As New Button()
okButton.Text = "OK"
okButton.Dock = DockStyle.Bottom
okButton.Height = 30
AddHandler okButton.Click, Sub(sender, e)
form.DialogResult = DialogResult.OK
form.Close()
End Sub
form.Controls.Add(okButton)
form.Controls.Add(panel)
form.ShowDialog()
Dim selectedDrawings As New List(Of String)()
For Each checkBox In checkBoxes
If CheckBox.Checked Then
selectedDrawings.Add(drawingFiles(checkBoxes.IndexOf(CheckBox)))
End If
Next
Return selectedDrawings
End Function
' Function to remove the last set of parentheses and its content from a string
Function RemoveLastParentheses(fileName As String) As String
Dim lastIndex As Integer = fileName.LastIndexOf("(")
If lastIndex <> -1 Then
' Remove everything from the last opening parenthesis to the end of the string
fileName = fileName.Substring(0, lastIndex).TrimEnd()
End If
Return fileName
End Function
' Function to display message in chunks with OK or Yes/No buttons
Function DisplayMessageInChunks(message As String, title As String, maxLines As Integer, isOkButton As Boolean, Optional footerText As String = "") As DialogResult
Dim lines() As String = message.Split(New String() {vbCrLf}, StringSplitOptions.None)
Dim totalLines As Integer = lines.Length
Dim currentLine As Integer = 0
Dim result As DialogResult = DialogResult.None
While currentLine < totalLines
Dim chunk As String = ""
For i As Integer = 0 To maxLines - 1
If currentLine >= totalLines Then Exit For
chunk = chunk & lines(currentLine) & vbCrLf
currentLine += 1
Next
' Append the footer text to the chunk
If footerText <> "" Then
chunk = chunk & vbCrLf & footerText
End If
If isOkButton Then
MessageBox.Show(chunk, title, MessageBoxButtons.OK, MessageBoxIcon.Information)
Else
result = MessageBox.Show(chunk, title, MessageBoxButtons.YesNo, MessageBoxIcon.Information)
If result = DialogResult.No Then
Exit While
End If
End If
End While
Return result
End Function
And here is my "copy sheets to drawing" code:
Sub Main
    ' Ensure the active document is a drawing document
    If ThisDoc.Document.DocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then
        MsgBox("A Drawing document must be active for this code to work. Exiting.", vbCritical, "")
        Exit Sub
    End If
    ' Define the active drawing document
    Dim oDDoc As DrawingDocument = ThisDoc.Document
    ' Get all open documents
    Dim openDocs As Documents = ThisApplication.Documents
    ' Iterate through all open documents
    For Each doc As Document In openDocs
        ' Check if the document is a drawing document and not the active document
        If doc.DocumentType = DocumentTypeEnum.kDrawingDocumentObject AndAlso doc.FullFileName <> oDDoc.FullFileName Then
            Dim oOtherDrawing As DrawingDocument = doc
            ' Copy each sheet from the other drawing document to the active document
            For Each oSheet As Sheet In oOtherDrawing.Sheets
                oSheet.CopyTo(oDDoc)
            Next
        End If
    Next
    ' Update the active document to reflect the copied sheets
    oDDoc.Update2(True)
End Sub
