I could not find a way using the api. But you could try to copy the InventorCustomization file.
Dim inventorVersion As String = "2020"
Dim destinationPath As String = "c:\temp\"
Dim fileName As String = "InventorCustomization.xml"
Dim appdataPath As String = System.Environment.ExpandEnvironmentVariables("%APPDATA%")
Dim lastPartPath As String = String.Format("Autodesk\Inventor {0}", inventorVersion)
Dim fullSourcePath As String = System.IO.Path.Combine(appdataPath, lastPartPath, fileName)
Dim fullDestinationPath As String = System.IO.Path.Combine(destinationPath, fileName)
If (System.IO.File.Exists(fullSourcePath)) Then
' copy the customization file to a save location
System.IO.File.Copy(fullSourcePath, fullDestinationPath, True)
Else
MsgBox("could Not find customization file")
End If
' do something else
' and return the customization file to its original location
System.IO.File.Copy(fullDestinationPath, fullSourcePath, True)
Jelte de Jong
Blog: hjalte.nl - github.com
