Can I check out the third party of the inventor dwg from the vault using ilogic?
skseo
skseo
Can I check out the 3rd party of the inventor dwg from the vault using ilogic?
3rd party document : autocad dwg, pdf
vault version : 2022 Professional
bradeneuropeArthur
Could you tell me if the files are only Vault attachments or that they are Inventor Third-party files as linked items?
Could you otherwise share an file with this structure?
Arthur Knoors
Arthur Knoors
Autodesk Affiliations:
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
skseo
Thank you for your interest in my question.
Attach a file related to the question.
