Calculate Length, width and Thickness
WRahmanK
WRahmanK
I am trying to calculate the length, width and thickness of a Plate,
Below is my code to calculate the length, Width & Thickness,
                           Inventor.Point maxpoint = Pdoc.ComponentDefinition.RangeBox.MaxPoint;
                            Inventor.Point minpoint = Pdoc.ComponentDefinition.RangeBox.MinPoint;
                            Inventor.Point2d p1 = InvApp.TransientGeometry.CreatePoint2d(0, 0);
                            Inventor.Point2d p2 = InvApp.TransientGeometry.CreatePoint2d(0, 0);
                            PlanarSketch sk = null;
                            List<double> db = new List<double>();
                            double[] arr = { maxpoint.X - minpoint.X, maxpoint.Y - minpoint.Y, maxpoint.Z - minpoint.Z };
                            //double[] arr = { p2.X - p1.X, p2.Y - p1.Y, 0 };
                            Array.Sort(arr);
                            db.Sort();
                            for (int i = 0; i < arr.Length; i++)
                                if (arr[i] < 0) { arr[i] = arr[i] * -1; }
                            double G_L = arr[2] * 10; //dbmax[dbmax.Count - 1] * 10;//
                            double G_W = arr[1] * 10; //dbmax[dbmax.Count - 2] * 10;
                            double G_H = arr[0] * 10; //db[0] * 10;
if the plate is aligned to any Default plane, I am getting the Length, Width & Thickness correctly, if the plate is not aligned to any Default Plane, then there is some outer boundary generated due to which the above code output wrong length, Width and Thickness.
Could anyone advice how to get only particular solid bodies and then calculate the length, width and Thickness, or any other best method to calculate these values.
jeremy.goenen
Hello, you could use the OrientedMinimumRangeBox. In a Multibodypart you would then specify the body.
Dim compdef As ComponentDefinition = ThisDoc.Document.ComponentDefinition
Dim minimumboundingbox As OrientedBox = compdef.OrientedMinimumRangeBox
Dim dir1, dir2, dir3 As Double
dir1 = Round(minimumboundingbox.DirectionOne.Length, 1) *10
dir2 = Round(minimumboundingbox.DirectionTwo.Length, 1) *10
dir3 = Round(minimumboundingbox.DirectionThree.Length, 1) * 10
' '----------Show axis If needed----------
'origin = compdef.WorkPoints.AddFixed(minimumboundingbox.CornerPoint) : origin.Name = "origin"
'dir1axis =  compdef.WorkAxes.AddFixed(minimumboundingbox.CornerPoint, minimumboundingbox.DirectionOne.AsUnitVector) : dir1axis.Name = "dir1axis"
'dir2axis =  compdef.WorkAxes.AddFixed(minimumboundingbox.CornerPoint, minimumboundingbox.DirectionTwo.AsUnitVector) : dir2axis.Name = "dir2axis"
'dir3axis =  compdef.WorkAxes.AddFixed(minimumboundingbox.CornerPoint, minimumboundingbox.DirectionThree.AsUnitVector) : dir3axis.Name = "dir3axis"
length = MaxOfMany(dir1, dir2, dir3)
width = MinOfMany(dir1, dir2, dir3)
height = (dir1 + dir2 + dir3) -length - width
Fanden Sie diesen Beitrag hilfreich? Fühlen Sie sich frei, diesen Beitrag zu liken.
Wurde Ihre Frage erfolgreich beantwortet? Klicken Sie dann auf die Schaltfläche LÖSUNG AKZEPTIEREN
Inventor Versionen:
2023.4.3
2025.2
WRahmanK
Thanks for the effort you put into this...
I cannot find 'OrientedMinimumRangeBox' API under ComponentDefinition
I think some dll reference need to be added to include Autodesk.Ilogic.Runtime  header in the coding...
if am i right please tell me what reference to add or else please help me with any possible solution...
bradeneuropeArthur
What version of Inventor are you using? Oriented rangebox has been implemented in later versions of Inventor.
Arthur Knoors
Autodesk Affiliations:
