Button icon for Net7
wmgshurik
wmgshurik
This code works pretty well for Net Frameork 4.8:
Image largeImage = Image.FromFile(pathLarge);
Image smallImage = Image.FromFile(pathSmall);
IconLarge = PictureConverter.ConvertImageToIPictureDisp(largeImage);
IconSmall = PictureConverter.ConvertImageToIPictureDisp(smallImage);
PipeButtonDef = controlDefs.AddButtonDefinition(" Pipeline ", "PipeID", CommandTypesEnum.kNonShapeEditCmdType, "", "", "", IconSmall, IconLarge);
private class PictureConverter : System.Windows.Forms.AxHost
    PictureConverter() : base("") { }
    public static stdole.IPictureDisp ConvertImageToIPictureDisp(Image Image)
        if (null == Image) return null;
        return (stdole.IPictureDisp)GetIPictureDispFromPicture(Image);
But on Net7 platform I catch the exception in method "ConvertImageToIPictureDisp". Interface not supported.
Does anybody know alternative way to set an image to buttonDefinition?
bradeneuropeArthur
Change the framework to an earlier one like 3.5
Arthur Knoors
Autodesk Affiliations:
wmgshurik
The problem could not be resolved. I had to work around the problem. One plugin(NetFramework4.8) makes icons, the other(Net7) subscribes to events.
